i added a simple Header to my Template with Logo and Menu. So i want to add a Text or other element. But i can't add everything to this section :-(
Have anyone an idea?
Stefan
Stefan
Have you tried deleting the header and starting it from the scratch?
1. Place an empty header.
2. Add logo
3. Add Menu
4. Add Text
I have just tried that method and worked
Hello, Have you tried deleting the header and starting it from the scratch? 1. Place an empty header. 2. Add logo 3. Add Menu 4. Add Text I have just tried that method and workedHi,
You mean that you can not insert any control within that Header? Please attach the problem theme (export with the editor included).
@greg41
How can i add an empty header? I didn' found this entry :-(
Stefan
@greg41 How can i add an empty header? I didn' found this entry :-( StefanHi,
Simply enable the header and then remove the section that is placed directly into it. It will be easy to do it in the left panel with the tree view enabled.
