Contact form in header section
bnk88
bnk88 posted this 20 April 2016
How I can create contact form on slider in header section.
Do you able to make any templates sections with this??
Hello How I can create contact form on slider in header section. Do you able to make any templates sections with this??
Support Team posted this 21 April 2016
To add a contact form you need to insert the Joomla Module Position within the Slide and then assign the module with the contact form to that position within your Joomla admin panel.
Hi, To add a contact form you need to insert the Joomla Module Position within the Slide and then assign the module with the contact form to that position within your Joomla admin panel. Sincerely, Hella
bnk88
Joomla.
Hi Joomla.
greg41
greg41 posted this 20 April 2016
What theme are you using? WordPress, HTML?
Hi, What theme are you using? WordPress, HTML?
