Google Fonts loaded only one time
funmaking
funmaking posted this 21 April 2016
I have seen every time I use a Google Font is loaded like a individual font. This way it's a problem because the loading time of the website is increasing a lot.
It's possible to use a unique link to Google Fonts if the same font used is defined in another link already?
This is an screenshot to see what's the problem. Thanks.
Hello I have seen every time I use a Google Font is loaded like a individual font. This way it's a problem because the loading time of the website is increasing a lot. It's possible to use a unique link to Google Fonts if the same font used is defined in another link already? This is an screenshot to see what's the problem. Thanks.
Stagger Lee posted this 21 April 2016
it is loaded allways only once, I believe. Browsers use fonts already downloaded. Those test tools works by hard reset all cache and are false positive in this regard.
funmaking
funmaking posted this 22 April 2016
But the same font is linked more than one time with different names. The ideal would be loaded only one time.
Stagger Lee posted this 22 April 2016
Explain first what is on this image. What tool.
Did you add some fonts manually in code ?
Explain first what is on this image. What tool. Did you add some fonts manually in code ?
funmaking
Hello Stagger,
It's a SEO analysis tool (Sistrix)
No, I haven't added any manually font to code, only the fonts used in Themler.
I have defined 2 custom Google fonts in the main configuration of Themler.
If I define the same font in any text or "hx" tag the font is loaded again. That one I think it's the problem.
Hello Stagger, It's a SEO analysis tool (Sistrix) No, I haven't added any manually font to code, only the fonts used in Themler. I have defined 2 custom Google fonts in the main configuration of Themler. If I define the same font in any text or "hx" tag the font is loaded again. That one I think it's the problem. Thank you
Support Team posted this 26 April 2016
I can't reproduce the problem. In Chrome Dev Tools I see only one font load for each used font. Can you please describe your problem in more details, how to reproduce this? Do you see problem in Chrome Dev Tools Network tab?
Themler Team
Hi, I can't reproduce the problem. In Chrome Dev Tools I see only one font load for each used font. Can you please describe your problem in more details, how to reproduce this? Do you see problem in Chrome Dev Tools Network tab? Thank you, Themler Team
