One more step to be Pefect in design - HOVER COLUM
designdrago
designdrago posted this 23 April 2016
After, all update, one missing to be pefect for design websites,
I think this is very nice to have option HOVER COLUM. Whith this option it be posibility give more effect to be full design which have other competitors app.
I hope the rest of the designers will support me in this proposal with voting.
Thank you in advance
After, all update, one missing to be pefect for design websites, I think this is very nice to have option HOVER COLUM. Whith this option it be posibility give more effect to be full design which have other competitors app. I hope the rest of the designers will support me in this proposal with voting. Thank you in advance
Support Team posted this 23 April 2016
Thanks for the suggestion. Maybe you could provide a link to the example of the site with this feature for better understanding.
Hi, Thanks for the suggestion. Maybe you could provide a link to the example of the site with this feature for better understanding. Sincerely, Hella
designdrago
Ofcource, I attached two files,
1. First files hemrantech is Themler Files
2. Second is Herman-tech is example what we need.
To explain, at example,
- at section "service" it is colums with effects, i give to change color, and size at hover etc..
- at section "testemonials" it is colums with only hover with no effect, -simply hover.
So what You can do for us, for begin to have only hover, when we have hover we can add shadow or border or fade color or more effect with existing tools which we have.
NOTICE: Please don"t use picture - Picture is property owner
Projects is My - so You can used :D
Thank You
Ofcource, I attached two files, 1. First files hemrantech is Themler Files 2. Second is Herman-tech is example what we need. To explain, at example, - at section "service" it is colums with effects, i give to change color, and size at hover etc.. - at section "testemonials" it is colums with only hover with no effect, -simply hover. So what You can do for us, for begin to have only hover, when we have hover we can add shadow or border or fade color or more effect with existing tools which we have. NOTICE: Please don"t use picture - Picture is property owner Projects is My - so You can used :D Thank You
designdrago
One more, I must ask you at contact form if i add to be button submit, in that case when i write text example SEND, when i try to save, text disappears and it is not possible to save with text. Can you resolved that please. Thank You.
Support Team posted this 27 April 2016
We've added your request to our wish list.
In general, you can try using HoveBox control to achieve effect of different background on hover.
But you will need to adjust z-index of the controls on background slide. Fir example, you can put them all into the Container control and then open Container's Arrange options and set position to "relative" and z-index to "1".
Our developers are aware about this issue. It should be fixed in the future Themler updates.
Hi, We've added your request to our wish list. In general, you can try using HoveBox control to achieve effect of different background on hover. But you will need to adjust z-index of the controls on background slide. Fir example, you can put them all into the Container control and then open Container's Arrange options and set position to "relative" and z-index to "1". > One more, I must ask you at contact form if i add to be button submit, in that case when i write text example SEND, when i try to save, text disappears and it is not possible to save with text. Our developers are aware about this issue. It should be fixed in the future Themler updates. Thank you, Olivia
