Slider contents doesn't get full page length
UrielG
UrielG posted this 23 April 2016
I have a section containing a slider. It in turn contains a couple of slides.
Now for the section and the slider lengths properties, I choice the "Page Width" value, in order for the contents to be able to use the full page width.
Nevertheless, Themler doens't allow me to move the elements that I want in every slide out of the general sheet width (which I use for other sections and their contents). It is like if the slides got by default either the value "Sheet width" or "Full background", instead of "Page Width" just like its parents containers.
Additionally, Themler doesn't offer the Length property for every of the slides inside a slider. So, how can this be fixed?
I have a section containing a slider. It in turn contains a couple of slides. Now for the section and the slider lengths properties, I choice the "Page Width" value, in order for the contents to be able to use the full page width. Nevertheless, Themler doens't allow me to move the elements that I want in every slide out of the general sheet width (which I use for other sections and their contents). It is like if the slides got by default either the value "Sheet width" or "Full background", instead of "Page Width" just like its parents containers. Additionally, Themler doesn't offer the Length property for every of the slides inside a slider. So, how can this be fixed?
Support Team posted this 25 April 2016
Please attach your theme so we could review the settings.
Hi, Please attach your theme so we could review the settings. Sincerely, Hella
UrielG
UrielG posted this 25 April 2016
Ok Hella, here it goes...
It was exported with the lastest version of Themler to date.
Ok Hella, here it goes... It was exported with the lastest version of Themler to date.
UrielG
UrielG posted this 28 April 2016
Is there any solution for this issue yet?
Support Team posted this 04 May 2016
Hello Uriel,
I'm terribly sorry for delay in response.
Unfortunately I cannot open your theme because it was saved without the 'Include Themler...' option.
However there should not be a problem with setting Slider to full page width. Here is an example
The Slider Length is set to Page Width
Text Control is added to Slide in absolute position
Here is the result from live page
If you cannot handle with it please re-save the theme with 'Include Themler...' option and attach here
Hello Uriel, I'm terribly sorry for delay in response. Unfortunately I cannot open your theme because it was saved without the 'Include Themler...' option. However there should not be a problem with setting Slider to full page width. Here is an example The Slider Length is set to Page Width Text Control is added to Slide in absolute position !SliderTextThemler.png! Here is the result from live page !SliderTextLive.png! If you cannot handle with it please re-save the theme with 'Include Themler...' option and attach here Regards, Aileen
