How I can remove the lightbox effect a template for joomla ?
ASSIN.COM.CO Asesorías y Soluciones Informáticas S.A.S
Good day,
Create a template for joomla worst show me all images with lightbox effect , including those with links to other pages, I want these did not have this effect , how can I remove ?
Good day, Create a template for joomla worst show me all images with lightbox effect , including those with links to other pages, I want these did not have this effect , how can I remove ?
Support Team posted this 26 April 2016
Please open each template in Themler and find the Posts control. Open the Post Content drop down from the Posts options and disable Lightbox option there.
Hi, Please open each template in Themler and find the Posts control. Open the Post Content drop down from the Posts options and disable Lightbox option there. Sincerely, Hella
Reviewing the program but can not find the option mentioned , I could send a snapshot para saber The location of esta Option ? .
Hi, Reviewing the program but can not find the option mentioned , I could send a snapshot para saber The location of esta Option ? .
Support Team posted this 10 June 2016
please follow the screenshot
Hello, please follow the screenshot !PostImg.png! regards, Aileen
Chiodoni Luigi SA
Chiodoni Luigi SA posted this 13 June 2016
I've a problem to change in a "Post" page. If I select "Post", Themler change immediately to "Page".
In that case I can't change the "Image Lightbox" option.
Marco
Hello, I've a problem to change in a "Post" page. If I select "Post", Themler change immediately to "Page". In that case I can't change the "Image Lightbox" option. regards, Marco
Support Team posted this 14 June 2016
Hi Marco,
It looks like it was the same issue as in your private case, which is solved now. Please feel free to contact us if any other questions or issues appear.
Hi Marco, It looks like it was the same issue as in your private case, which is solved now. Please feel free to contact us if any other questions or issues appear. Sincerely, Nettie, BillionDigital Team
ABSolutions
ABSolutions posted this 11 April 2017
Marco
I am having this issue as well. I want to turn off lightbox, but when I select the "Post" template it changes to the "Page" template.
AB
> Hello, > I've a problem to change in a "Post" page. If I select "Post", Themler change immediately to "Page". > In that case I can't change the "Image Lightbox" option. > regards, > Marco I am having this issue as well. I want to turn off lightbox, but when I select the "Post" template it changes to the "Page" template. AB
Support Team posted this 11 April 2017
That means that the Post template is not activated on your site. Please refer to the following article:
https://answers.themler.com/articles/36343/how-to-work-with-templates-in-joomla-themes
If that does not help, create a private ticket and provide an access to the site back end and point to the exact image that should not have the lightbox effect.
Hi, That means that the Post template is not activated on your site. Please refer to the following article: https://answers.themler.com/articles/36343/how-to-work-with-templates-in-joomla-themes If that does not help, create a private ticket and provide an access to the site back end and point to the exact image that should not have the lightbox effect. Sincerely, Hella
