problem with jquery
williwirz1952
williwirz1952 posted this 26 April 2016
I have a problem with a plugin and asked the developer to have a look. He wrote me:
"your theme loads an additional (and old) version of jquery alongside the version that comes with WP.
that’s never a good idea in any case, and I suspect your problem lies there
(doing that will most likely also cause many other issues now or in the future)"
I use Themler theme TrePesciolino and asked Eugene, giving the response above. Eugene wrote back:
"TrePesciolino theme is a Themler theme. It includes jQuery version same as any Themler theme for Wordpress, e.g. like default Themler theme.
As I understand, Themler themes for Wordpress include 2 jQuery files: one from WP, second from the Theme. They both can work together in the same page, because they use jQuery.noConflict() method:
https://api.jquery.com/jquery.noconflict/
So Themler theme uses jQuery from theme, while all other scripts, e.g. from plugins, use jQuery from WP.
If you have any other questions about jQuery version in the theme, please contact Themler support. They should have more information."
I just upgraded Themler but when I click on Save and Publish I get a box with the text below and I can only click OK:
"www.deluxpizza.ch says:
sorry, error occurred, your project will be restored."
When I click OK Themler reloads.
The site is www.deluxpizza.ch
Any suggestion from your part and how do I upgrade Themler without getting that error?
Thank you and best regards
Hi, I have a problem with a plugin and asked the developer to have a look. He wrote me: "your theme loads an additional (and old) version of jquery alongside the version that comes with WP. that’s never a good idea in any case, and I suspect your problem lies there (doing that will most likely also cause many other issues now or in the future)" I use Themler theme TrePesciolino and asked Eugene, giving the response above. Eugene wrote back: "TrePesciolino theme is a Themler theme. It includes jQuery version same as any Themler theme for Wordpress, e.g. like default Themler theme. As I understand, Themler themes for Wordpress include 2 jQuery files: one from WP, second from the Theme. They both can work together in the same page, because they use jQuery.noConflict() method: https://api.jquery.com/jquery.noconflict/ So Themler theme uses jQuery from theme, while all other scripts, e.g. from plugins, use jQuery from WP. If you have any other questions about jQuery version in the theme, please contact Themler support. They should have more information." I just upgraded Themler but when I click on Save and Publish I get a box with the text below and I can only click OK: "www.deluxpizza.ch says: sorry, error occurred, your project will be restored." When I click OK Themler reloads. The site is [www.deluxpizza.ch][1] Any suggestion from your part and how do I upgrade Themler without getting that error? Thank you and best regards [1]: http://www.deluxpizza.ch
Support Team posted this 04 May 2016
I'm very sorry for delay in response.
Themler theme loads jQuery.js file which is needed to make theme working properly. In general it should not cause a problem or conflict. The error you reported
may have different reasons, but I do not think that it is caused by jquery.js file. Please provide access to your WP admin back end and we'll investigate this issue
Hello, I'm very sorry for delay in response. Themler theme loads jQuery.js file which is needed to make theme working properly. In general it should not cause a problem or conflict. The error you reported > sorry, error occurred, your project will be restored may have different reasons, but I do not think that it is caused by jquery.js file. Please provide access to your WP admin back end and we'll investigate this issue regards, Aileen
williwirz1952
williwirz1952 posted this 04 May 2016
Thank you for your reply,
I was able to solve the issue.
Thank you for your reply, I was able to solve the issue.
alexarafatonline
alexarafatonline posted this 31 October 2025
Thanks for the insights. I’ve been struggling with the same issue after upgrading Themler—clicking Save and Publish just shows the error and reloads the project. It reminds me of the time I had to get federal documents ready for an international trip under a tight deadline. I used expedited apostille services to get a federal apostille, which proved my documents were real so another country would accept them. Just like that process, upgrading Themler seems to need careful steps and the right support to avoid errors. I might reach out to Themler support directly for a clean upgrade.
Thanks for the insights. I’ve been struggling with the same issue after upgrading Themler—clicking Save and Publish just shows the error and reloads the project. It reminds me of the time I had to get federal documents ready for an international trip under a tight deadline. I used [expedited apostille services][1] to get a federal apostille, which proved my documents were real so another country would accept them. Just like that process, upgrading Themler seems to need careful steps and the right support to avoid errors. I might reach out to Themler support directly for a clean upgrade. [1]: https://federalapostille.com/
doblenacionalidaddnexpress
doblenacionalidaddnexpress posted this 29 April 2026
Conflicting jQuery versions can definitely cause errors like that. While resolving technical issues is key, our dual citizenship services to US citizens of Mexico ensure your important documentation processes stay smooth and stress-free.
Conflicting jQuery versions can definitely cause errors like that. While resolving technical issues is key, our [dual citizenship services][1] to US citizens of Mexico ensure your important documentation processes stay smooth and stress-free. [1]: https://dnexpress.org/products/mexican-citizenship
lebavo1328
lebavo1328 posted this 29 April 2026
Inspired by the legacy of Gander Mountain, the website helps users explore reliable products and discover trusted options for their adventures. Rather than selling directly, it often guides visitors to well-known retailers, making it easier to compare choices and find the best deals.
Inspired by the legacy of [Gander Mountain][1], the website helps users explore reliable products and discover trusted options for their adventures. Rather than selling directly, it often guides visitors to well-known retailers, making it easier to compare choices and find the best deals. [1]: https://gandermountains.us/
