Request to Bring back 24 column size vs new 12.
letstalklocal
letstalklocal posted this 27 April 2016
Please bring back the 24 column size. This gives us more granular control. I have a theme I use that will break the column format if I update to the 12 columns.
Why does it have to change. This makes Themler more powerful to have this control.
Please bring back the 24 column size. This gives us more granular control. I have a theme I use that will break the column format if I update to the 12 columns. Why does it have to change. This makes Themler more powerful to have this control.
Support Team posted this 27 April 2016
We had a lot of requests to change our themes to the 12-column grid as most plug-ins and extension do use it. So that's the reason. Your theme should not break after the update, but in any case you can make a back-up template.
Hi, We had a lot of requests to change our themes to the 12-column grid as most plug-ins and extension do use it. So that's the reason. Your theme should not break after the update, but in any case you can make a back-up template. Sincerely, Hella
letstalklocal
letstalklocal posted this 24 June 2016
Please explain how am I supposed to breakup 5 columns evenly using 12 columns. Is there a way to give the user the option to pick 12 or 24. If I keep the old template I won't be able to update. The granular control has been lost, there a way to over write this setting in the code?
letstalklocal
right now I have a 5-5--4-5-5 format.
Support Team posted this 24 June 2016
Unfortunately there is no way to switch to the 24-column grid back. But in the 24-grid there also was no possibility to create 5 equal columns.
You can use the solution from other Bootstrap users with the same problem:
http://www.wearesicc.com/quick-tips-5-column-layout-with-twitter-bootstrap/
Hi, Unfortunately there is no way to switch to the 24-column grid back. But in the 24-grid there also was no possibility to create 5 equal columns. You can use the solution from other Bootstrap users with the same problem: http://www.wearesicc.com/quick-tips-5-column-layout-with-twitter-bootstrap/ Sincerely, Hella
