When I insert adsense code in HTML area in the themler and clcik OK button, my code is changed! Why!
ssharma
ssharma posted this 04 May 2016
Hi guys
As always software is superb! I have an issue though!
Please refer to the two attached pictures.
Top one is correct code that I copy from my google account.
Second (bottom) is the incorrect code after I press OK in the HTML edit box in the themler! It changes the code by itself! It should not happen! Please help.
Subodh
Hi guys As always software is superb! I have an issue though! Please refer to the two attached pictures. Top one is correct code that I copy from my google account. Second (bottom) is the incorrect code after I press OK in the HTML edit box in the themler! It changes the code by itself! It should not happen! Please help. Thanks Subodh!correct-actual.png!!incorrect-changed.png!
10 Comments
Support Team posted this 05 May 2016
Try to use the CMS Code control.
Let us know if it works better.
Hi, Try to use the CMS Code control. Let us know if it works better. Sincerely, Hella
ssharma
ssharma posted this 05 May 2016
Hi Hella, team
Code is staying good after I used the CMS Code control. It is not changing! (Good sign! )Once I go live on my actual website, I will update you guys if ads are actually working alright. :)
Thanks a lot for your help.
You guys Rock!
Subodh
Hi Hella, team Code is staying good after I used the CMS Code control. It is not changing! (Good sign! )Once I go live on my actual website, I will update you guys if ads are actually working alright. :) Thanks a lot for your help. You guys Rock! Subodh
Support Team posted this 06 May 2016
You are welcome. Please let us know if you need our further assistance.
Hi, You are welcome. Please let us know if you need our further assistance. Sincerely, Hella
ssharma
ssharma posted this 06 May 2016
Hi Hella
UPDATE: Sorry, I don't know the reason yet but my ads are not showing in the sidebars (above and below cms content). neither in themler nor on a live website. Hopefully I will find it and update here. meanwhile if you guys work on something please reply this thread, please ! Thanks. Subodh
Hi Hella UPDATE: Sorry, I don't know the reason yet but my ads are not showing in the sidebars (above and below cms content). neither in themler nor on a live website. Hopefully I will find it and update here. meanwhile if you guys work on something please reply this thread, please ! Thanks. Subodh
Support Team posted this 10 May 2016
Maybe the issue is in the code? Does it work in your site with any other template? Also have you tried to add it as the widget within your WP admin?
If that does not help, attach your theme to the ticket (export it with the editor included).
Hi, Maybe the issue is in the code? Does it work in your site with any other template? Also have you tried to add it as the widget within your WP admin? If that does not help, attach your theme to the ticket (export it with the editor included). Sincerely, Hella
desterradomgh
desterradomgh posted this 10 May 2016
Hola ssharma: Yo tenía el mismo problema y lo resolví de esta forma:
La publicidad la tengo en una “columns”, puse dentro un “container” y dentro un “Block”.
En el “Block” coloqué la publicidad (script) en “Content”.
Editas el Block si lo deseas.
Hasta el momento no me ha agregado más código.
Espero que permanezca así.
Buen día.
(Translator)
Hello ssharma: I had the same problem and solved it this way:
Advertising have it in a "columns”, put within "container" and within "Block “.
In the " Block" I put advertising (script) on "Content “.
Block edit as desired.
So far you have not added me more code.
I hope to remain so.
Good day.
Hola ssharma: Yo tenía el mismo problema y lo resolví de esta forma: La publicidad la tengo en una “columns”, puse dentro un “container” y dentro un “Block”. En el “Block” coloqué la publicidad (script) en “Content”. Editas el Block si lo deseas. Hasta el momento no me ha agregado más código. Espero que permanezca así. Buen día. (Translator) Hello ssharma: I had the same problem and solved it this way: Advertising have it in a "columns”, put within "container" and within "Block “. In the " Block" I put advertising (script) on "Content “. Block edit as desired. So far you have not added me more code. I hope to remain so. Good day.
ssharma
ssharma posted this 19 May 2016
Hi desterradomgh, thanks alot for your help. I am trying it and will update here
@Hella: widgets works perfectly on the sidebars. Code works perfectly if I go and add it in the individual pages in WP admin. But then I have to add individually each time I put up a post or page. I want to do it in the Themler so that it is there for once and all.
I could not work on it last 2 weeks. so will update further as I progress
Hi desterradomgh, thanks alot for your help. I am trying it and will update here @Hella: widgets works perfectly on the sidebars. Code works perfectly if I go and add it in the individual pages in WP admin. But then I have to add individually each time I put up a post or page. I want to do it in the Themler so that it is there for once and all. I could not work on it last 2 weeks. so will update further as I progress
ssharma
Finally! adding WP widget area directly into the above and below content bars is working good!
@Hella: I still feel that it a workaround and HTML code should not be modified and CMS code shouls ot stay blank. All though I have solved my issue but for long run I will say it is a check to be don
Nevertheless, thanks for the great work by you guys!
Thanks desterradomgh for giving a clue and a subsequent success :)
Subodh
Finally! adding WP widget area directly into the above and below content bars is working good! @Hella: I still feel that it a workaround and HTML code should not be modified and CMS code shouls ot stay blank. All though I have solved my issue but for long run I will say it is a check to be don Nevertheless, thanks for the great work by you guys! Thanks desterradomgh for giving a clue and a subsequent success :) Subodh
ssharma
ssharma posted this 20 May 2016
By the way my website is http://subodhsharma.com
edwardterrya7725
edwardterrya7725 posted this 11 September 2024
After I utilized the CMS Code control, the code is still working well. Nothing is changing!
roof paint nz
After I utilized the CMS Code control, the code is still working well. Nothing is changing! . . . [roof paint nz][1] [1]: https://roofpaintingauckland.co.nz/
