In the latest version of themler, is this still the case where the two options of SAVE and PUBLISH do the same task; apply the changes to both the preview of the theme and publish the theme, or is this a bug?. I ask this because like the original poster (from 2 years ago) I would have thought that SAVE would save the changes to the template in the preview and PUBLISH would then publish it to the CMS (wordpress in this case)
If it is the case then why have the two buttons, as this is a real "got you there moment" when working on a live site. Halfway through making some large changes to the theme (so it looks a mess) click save to end the days work with plans to continue the next day, check the site and see that save button has published all the changes so the live site is now a mess.
Lucky before I made the changes I backed up the theme so I can restore back however this is not perfect either and I still had to spend 2 hours extra tidying it up, a waste of my time.
If this is not a bug, I would think that rectify this would be at the top of the list of things to address as it is pretty major and very counter intuitive on the UI. Either combine the two into one clear action that is "Save and Publish" or make the button function as would be intuitive given their labels.
Josh
In the latest version of themler, is this still the case where the two options of **SAVE** and **PUBLISH** do the same task; apply the changes to both the preview of the theme and publish the theme, or is this a bug?. I ask this because like the original poster (from 2 years ago) I would have thought that **SAVE** would save the changes to the template in the preview and **PUBLISH** would then publish it to the CMS (wordpress in this case)
If it is the case then why have the two buttons, as this is a real **"got you there moment"** when working on a live site. Halfway through making some large changes to the theme (so it looks a mess) click save to end the days work with plans to continue the next day, check the site and see that save button has published all the changes so the live site is now a mess.
Josh
