multiples images selection in slider
frederic11
frederic11 posted this 11 May 2016
i make sliders, with multiples images, with same size. If i put an image, with fade in at 2 secondes, and after, i put another image on the first, with the same size, i can't select the first for modify the fade for example, because she is under the second. I make slide with 4-5-6 images.
So is it a way to can select the images independently ?
Frédéric
Hello, i make sliders, with multiples images, with same size. If i put an image, with fade in at 2 secondes, and after, i put another image on the first, with the same size, i can't select the first for modify the fade for example, because she is under the second. I make slide with 4-5-6 images. So is it a way to can select the images independently ? Regards, Frédéric
Support Team posted this 11 May 2016
You can select them in the left panel within the tree view, all the controls should be listed there.
Hi, You can select them in the left panel within the tree view, all the controls should be listed there. Sincerely, Hella
frederic11
Hum,
OK, i did not see it before... Thank you
Hum, OK, i did not see it before... Thank you
Support Team posted this 12 May 2016
