Is there a way to center the CMS content within the sheet ?
Olivier
Olivier
After 3 hours of battle I succeded...
Sorry for the delay. Nice to hear that you have found the solution.
What did you do ?Can you explain. Mine Align option at Home tab is greyed out.
What did you do ?Can you explain. Mine Align option at Home tab is greyed out.Hi,
In the "post" tab try to erase all parameters e.g. padding, margin, extension, etc. of the "Posts" element
I just did it. No help, seems as it is connected to some other wrapping options. Sidebars & Content maybe. I tried to change all options everywhere but cannot force it. I know I could use position absolute old way, but would like to avoid it and use some build in options. It makes more problems with different browsers than use.
I just did it. No help, seems as it is connected to some other wrapping options. Sidebars & Content maybe. I tried to change all options everywhere but cannot force it. I know I could use position absolute old way, but would like to avoid it and use some build in options. It makes more problems with different browsers than use.I am really sorry, my bad.
I see now you are talking about horizontal centering. I am asking for vertical centering of content area.
I am really sorry, my bad. I see now you are talking about horizontal centering. I am asking for vertical centering of content area.Hello Stagger Lee,
to align content vertically you may add Container and assign it 'Align Content' extension
Doesnt work all the time.
Problem is it is very difficult to move all Post blocks to container that has those easy align options.
What I do is following:
Dragging doesnt work here.
But I am afraid I am making some other, for now, hidden problems for future.
Very specific, I am looking for easy way to put Content & Sidebars to some "Easy align" already by Themler prepared container, Section, Layout container, etc. Or as it seems Content & Sidebars cannot be moved at least put CMS Content - Posts inside those align blocks.
Doesnt work all the time. Problem is it is very difficult to move all Post blocks to container that has those easy align options. What I do is following: - Copy one block from content area - Paste (Not Paste Link, very important) - Then I delete this content block Dragging doesnt work here. But I am afraid I am making some other, for now, hidden problems for future. Very specific, I am looking for easy way to put Content & Sidebars to some "Easy align" already by Themler prepared container, Section, Layout container, etc. Or as it seems Content & Sidebars cannot be moved at least put CMS Content - Posts inside those align blocks.Hello Stagger Lee,
thank you for your comments regarding easy align, I'll pass them to developer team.
If you have problems with locating controls in one of your themes we'll be happy to help you
