Drupal - Post Image Control
Stagger Lee posted this 12 May 2016
What is Post Image control in Drupal Themler part ?
Using in-core image field doesnt show image in this control (it shows in Post Content control). How to show images in Teasers ?
What is Post Image control in Drupal Themler part ? Using in-core image field doesnt show image in this control (it shows in Post Content control). How to show images in Teasers ?
52 Comments
Support Team posted this 16 May 2016
Unfortunately Post Image does not work in Drupal as it works in WP.
Image field is not accessible from node.tpl.php and it does not have own variable.
Drupal does not have control similar to WP Post featured Image.
Hi, Unfortunately Post Image does not work in Drupal as it works in WP. Image field is not accessible from node.tpl.php and it does not have own variable. Drupal does not have control similar to WP Post featured Image. Thank you, Olivia
Stagger Lee posted this 16 May 2016
I checked on Cloud, Post controls (any) are possible to insert inside post elements just in Blog template (not Home, Default or any custom archive template). And Blog template can be used only once per website.
Please, have some intern meeting regarding Drupal part in Themler. It doesnt go like this way. It lags behind WordPress and any other CMS big time.
I checked on Cloud, Post controls (any) are possible to insert inside post elements just in Blog template (not Home, Default or any custom archive template). And Blog template can be used only once per website. Please, have some intern meeting regarding Drupal part in Themler. It doesnt go like this way. It lags behind WordPress and any other CMS big time.
Support Team posted this 18 May 2016
Not exactly. Posts control in the only control that outputs CMS content (posts, pages, articles). Any of available Posts controls can be inserted on any of the supported templates:
The problem is that in some cases there is nothing to show inside control and you may not see the added control.
The Post Image displays author avatar if exists and enabled.
This control cannot output the content of image fields because there is no particular variable to take this image. The machine name of fields may be different for different content types and cannot be edited.
If you have a theme where you do not have Posts contro you can enable it under the Layout tab >> Content & Sidebars >> CMS Content. If you cannot insert any of existing Posts controls available under "Add Control" please attach the problem theme.
Hi, > I checked on Cloud, Post controls (any) are possible to insert inside post elements just in Blog template (not Home, Default or any custom archive template). Not exactly. Posts control in the only control that outputs CMS content (posts, pages, articles). Any of available Posts controls can be inserted on any of the supported templates: !insert-post-image.png! The problem is that in some cases there is nothing to show inside control and you may not see the added control. The Post Image displays author avatar if exists and enabled. This control cannot output the content of image fields because there is no particular variable to take this image. The machine name of fields may be different for different content types and cannot be edited. If you have a theme where you do not have Posts contro you can enable it under the Layout tab >> Content & Sidebars >> CMS Content. If you cannot insert any of existing Posts controls available under "Add Control" please attach the problem theme. Thank you, Olivia
frederickgragg
frederickgragg posted this 28 June 2025
Achieve your Salesforce certification goals with confidence! Our expertly designed study resources, real-world scenarios, and practice exams help you master key concepts and ace your exam on the first try. Whether you're aiming for Administrator, Developer, or Consultant certifications, we provide the guidance and tools you need to succeed. Join thousands of professionals who have advanced their careers through Salesforce certification. With clear explanations, updated materials, and insider tips, you'll gain the skills and knowledge to stand out in the competitive https://www.dumpsmate.com/Salesforce.html ecosystem. Prepare smarter, not harder—your Salesforce exam success starts here!
Achieve your Salesforce certification goals with confidence! Our expertly designed study resources, real-world scenarios, and practice exams help you master key concepts and ace your exam on the first try. Whether you're aiming for Administrator, Developer, or Consultant certifications, we provide the guidance and tools you need to succeed. Join thousands of professionals who have advanced their careers through Salesforce certification. With clear explanations, updated materials, and insider tips, you'll gain the skills and knowledge to stand out in the competitive [https://www.dumpsmate.com/Salesforce.html][1] ecosystem. Prepare smarter, not harder—your Salesforce exam success starts here! [1]: https://www.dumpsmate.com/Salesforce.html
sergiotony45
sergiotony45 posted this 29 June 2025
Managing post images in Drupal is streamlined through its flexible content management system and robust module support. With the Image field feature, site administrators can see easily add image upload capabilities to content types, allowing users to attach images to posts. Additional control over image display, size, alignment, and cropping can be achieved using the Image Styles and Media modules.
Managing post images in Drupal is streamlined through its flexible content management system and robust module support. With the Image field feature, site administrators can [see][1] easily add image upload capabilities to content types, allowing users to attach images to posts. Additional control over image display, size, alignment, and cropping can be achieved using the Image Styles and Media modules. [1]: https://royaldreamapk.com/royal-dream-x8-speeder/
darriustanz79
darriustanz79 posted this 22 September 2025
The Post Image control in Drupal Themler is specifically designed to display an image associated with a post, usually from a custom or designated image field. If you're using the in-core image field and it's not appearing in the Post Image control (but does show in Post Content), it's likely that Themler isn't recognizing the field automatically.
To fix this for Teasers, make sure:
The image field is set to display in the "Teaser" view mode under Manage Display.
You assign the correct field as the main image in Themler’s settings or use a custom field mapping.
For optimized performance and better control of your site features, explore tools that make your apps run 8x faster.
The Post Image control in Drupal Themler is specifically designed to display an image associated with a post, usually from a custom or designated image field. If you're using the in-core image field and it's not appearing in the Post Image control (but does show in Post Content), it's likely that Themler isn't recognizing the field automatically. To fix this for Teasers, make sure: The image field is set to display in the "Teaser" view mode under Manage Display. You assign the correct field as the main image in Themler’s settings or use a custom field mapping. For optimized performance and better control of your site features, explore tools that make your apps run [8x faster][1]. [1]: https://royaldreamapk.id/royal-dream-x8-speeder/
gamevault999dl
gamevault999dl posted this 22 September 2025
Game Vault 999 is a popular online gaming platform offering a wide variety of exciting casino-style games with smooth gameplay and top-notch graphics. Whether you're a casual player or a gaming enthusiast, it provides endless entertainment at your fingertips. Ready to get started? Download GameVault999
now and experience the thrill!
Game Vault 999 is a popular online gaming platform offering a wide variety of exciting casino-style games with smooth gameplay and top-notch graphics. Whether you're a casual player or a gaming enthusiast, it provides endless entertainment at your fingertips. Ready to get started? [Download GameVault999][1] now and experience the thrill! [1]: https://gamevault999app.net/
hoorainwali252
hoorainwali252 posted this 22 September 2025
RiverSweeps 777 is a popular online sweepstakes platform offering a variety of casino-style games, including slots, fish games, and more. To start playing and enjoy seamless access across your devices, simply riversweeps download from the official site.
RiverSweeps 777 is a popular online sweepstakes platform offering a variety of casino-style games, including slots, fish games, and more. To start playing and enjoy seamless access across your devices, simply [riversweeps download][1] from the official site. [1]: https://riversweepsapk.com/
badurkhan414
badurkhan414 posted this 22 September 2025
Looking for a smooth and secure way to enjoy mobile gaming? Try Game Vault 777 iOS download
and experience top-notch entertainment right on your iPhone with easy access and seamless gameplay.
Looking for a smooth and secure way to enjoy mobile gaming? Try [Game Vault 777 iOS download][1] and experience top-notch entertainment right on your iPhone with easy access and seamless gameplay. [1]: https://gamevault-777.us/
arjeetrajen
arjeetrajen posted this 22 September 2025
Fly 33 is an exciting and fast-paced mobile game that challenges players to navigate through thrilling obstacles while aiming for the highest score. With its addictive gameplay and sleek design, it’s perfect for casual gamers looking for fun on the go. Ready to play? Click here for the Fly 33 game download and start your adventure now
Fly 33 is an exciting and fast-paced mobile game that challenges players to navigate through thrilling obstacles while aiming for the highest score. With its addictive gameplay and sleek design, it’s perfect for casual gamers looking for fun on the go. Ready to play? Click here for the [Fly 33 game download][1] and start your adventure now [1]: https://fly33game.net.pk/
khanjhonson86
khanjhonson86 posted this 22 September 2025
Lucky 101 is a popular online gaming platform in Pakistan, offering users an exciting chance to win real rewards through engaging games and daily challenges. Whether you're a casual player or a seasoned gamer, Lucky 101 provides a fun and rewarding experience. To get started, simply Lucky 101 game download and join thousands of players enjoying the thrill today.
Lucky 101 is a popular online gaming platform in Pakistan, offering users an exciting chance to win real rewards through engaging games and daily challenges. Whether you're a casual player or a seasoned gamer, Lucky 101 provides a fun and rewarding experience. To get started, simply [Lucky 101 game download][1] and join thousands of players enjoying the thrill today. [1]: https://lucky101app.net/
davidbion11
davidbion11 posted this 27 October 2025
That’s a great question about the Post Image control in Drupal Themler. Sometimes, the in-core image field not displaying properly in teaser mode happens due to how Themler handles dynamic content blocks. Setting the correct “Image Style” and ensuring the field is included in the Manage Display settings usually fixes it.
Also, for developers working with dynamic data feeds or sports updates, integrating reliable data sources can enhance user engagement significantly. For example, NowGoal Goaloo provide real-time football statistics and match results that can be embedded into Drupal sites to create automated sports pages.
Combining CMS flexibility with live sports APIs really opens up endless possibilities for interactive, data-driven web projects.
That’s a great question about the Post Image control in Drupal Themler. Sometimes, the in-core image field not displaying properly in teaser mode happens due to how Themler handles dynamic content blocks. Setting the correct “Image Style” and ensuring the field is included in the Manage Display settings usually fixes it. Also, for developers working with dynamic data feeds or sports updates, integrating reliable data sources can enhance user engagement significantly. For example, [NowGoal Goaloo][1] provide real-time football statistics and match results that can be embedded into Drupal sites to create automated sports pages. Combining CMS flexibility with live sports APIs really opens up endless possibilities for interactive, data-driven web projects. [1]: https://nowgoaloo.xyz
Aly
Aly posted this 07 November 2025
Nice post. Bn55
Nice post. **[Bn55][1]** [1]: https://bn55game.net.pk/
Aly
Aly posted this 09 November 2025
Want a safe and easy way to play games on your phone? Download Lucky PKR Game and enjoy fun, smooth gaming on your Android with simple access and great play.
Want a safe and easy way to play games on your phone? **[Download Lucky PKR Game][1]** and enjoy fun, smooth gaming on your Android with simple access and great play. [1]: https://luckypkr.cc/
atiyaati14
atiyaati14 posted this 09 November 2025
Star Game is a fun online gaming app where you can play many exciting casino-style games. It’s easy to use, looks great, and runs smoothly. Whether you play just for fun or love gaming, you’ll always have a good time. Star Game Download now and enjoy the excitement!
Star Game is a fun online gaming app where you can play many exciting casino-style games. It’s easy to use, looks great, and runs smoothly. Whether you play just for fun or love gaming, you’ll always have a good time. **[Star Game Download] [1]** now and enjoy the excitement! [1]: https://star-game.pro/
atiyaati14
BN55 Game is an online gaming app that offers lots of fun casino-style games. It’s easy to play, has great graphics, and gives you a smooth gaming experience. Whether you’re a beginner or a pro, BN55 Game is full of excitement. Download BN55 Game now and start playing.
BN55 Game is an online gaming app that offers lots of fun casino-style games. It’s easy to play, has great graphics, and gives you a smooth gaming experience. Whether you’re a beginner or a pro, **[BN55 Game][1]** is full of excitement. Download BN55 Game now and start playing. [1]: https://bn55game.net.pk/
atiyaati14
Fly33 Game: Play Fly33 Game on your Android and enjoy smooth, exciting mobile gaming anytime, anywhere.
**[Fly33 Game][1]**: Play Fly33 Game on your Android and enjoy smooth, exciting mobile gaming anytime, anywhere. [1]: http://fly33game.net.pk
atiyaati14
atiyaati14 posted this 10 November 2025
Download CK999 Game this is new platform in market.
**[Download CK999 Game][1]** this is new platform in market. [1]: https://ck999game.net.pk/
akramnazeer1122
akramnazeer1122 posted this 14 November 2025
Lulubox is a game management tool that allows players to organize their mobile games, with features that claim to enhance gameplay experience and provide easier access to in‑game resources.
[Lulubox][1] is a game management tool that allows players to organize their mobile games, with features that claim to enhance gameplay experience and provide easier access to in‑game resources. [1]: https://luluboxproapk.com
akramnazeer1122
1v1 lol is such a fun and addictive game! I love how fast-paced it is and how every match feels different. Perfect for testing your skills and having a laugh at the same time!"
[1v1 lol][1] is such a fun and addictive game! I love how fast-paced it is and how every match feels different. Perfect for testing your skills and having a laugh at the same time!" [1]: https://1v1lol.net/
