Problem in templates
info104
info104 posted this 15 May 2016
Hello.
I made templates for and now I see it on picture is in the attachment. Please help.
V.Střelka
Hello. I made templates for and now I see it on picture is in the attachment. Please help. Thanks V.Střelka!themler-template.gif!!themler-template.gif!
Support Team posted this 16 May 2016
Could you please try the solution provided here:
http://answers.themler.com/articles/65525/themler-themes-issues-drupal
It should help.
Hi, Could you please try the solution provided here: http://answers.themler.com/articles/65525/themler-themes-issues-drupal It should help. Please let us know the result. Thank you, Olivia
info104
info104 posted this 22 May 2016
Hi.
But I have problem inThemler.. ASfter that I have problem in webpages. At first I need fix problem in Themler.
V.Střelka
It should help.
Hi. But I have problem inThemler.. ASfter that I have problem in webpages. At first I need fix problem in Themler. V.Střelka > Hi, > > Could you please try the solution provided here: > http://answers.themler.com/articles/65525/themler-themes-issues-drupal > > It should help. > Please let us know the result. > > Thank you, > Olivia
Support Team posted this 25 May 2016
Hello Valdemar,
I see the issue with your theme. I'm passing it to developers for review and we'll contact you when solution or workaround is available.
Hello Valdemar, I see the issue with your theme. I'm passing it to developers for review and we'll contact you when solution or workaround is available. Regards, Aileen
Support Team posted this 26 May 2016
Hello Valdemar,
I'm attaching the restored theme.
Use Import from ZIP Themler option to apply it.
Let us know the results.
Hello Valdemar, I'm attaching the restored theme. Use Import from ZIP Themler option to apply it. Let us know the results. regards, Aileen
