Add hover effects to columns.
Turn columns into links.
thanks
DP
thanks
DP
Hello David,
we're planning to add special Box control that has onHover state. It allows to change background color with transition effects. The Box may be located inside other controls like Row with Columns and inside the Box you may locate different controls, e.g. Joomla modules
Right now to add hover effect for a DIV or image, etc. custom CSS code is needed. Here is a couple of good samples
http://www.corelangs.com/css/box/hover.html
Czy ten box do hover background został już dodany jak tak to jak tego użyć
Czy ten box do hover background został już dodany jak tak to jak tego użyćHello,
please refer to this article for details about Hover Box control
http://answers.themler.com/articles/8397/hover-box
Is there still no way to do Column Background color change on hover?
Is there still no way to do Column Background color change on hover?Hello,
You may consider to put the Hover Box over the column and set colors there. Let us know if any additional questions appear in process.
