Today I have installed 2 new sites on new joomla. Unable to install templates, on 3.3.6 install ok. Different hostings.
And templates installed before up to v3.4 works fine (3.3.6 to 3.4)
Indeed, there is a problem with installing Themler themes on latest Joomla 3.4 released two days ago.
Our developers are working on this issue with high priority. We'll fix it ASAP.
In the meantime you can install theme by FTP, then go to Extensions Manager >> Discover >> click "Discover" and then "Install" buttons.
The FTP installation works ok.
Thanks Olivia
PS
...indeed" sounds like a Teal'c :-)
I have the same problem, but maybe you should also look if the problem is not just Joomla based.
I have the same problem, but maybe you should also look if the problem is not just Joomla based.Same problem. Sort of has me at a standstill...
Same problem. Sort of has me at a standstill...if i install the template via the discover function, i can not edit the template directly. I get all kinds of error messages
if i install the template via the discover function, i can not edit the template directly. I get all kinds of error messagesThe people at Joomla have found this problem and it will be fixed in 3.4.1. If you don't want to wait for 3.4.1 please read this post from RSJoomla
https://www.rsjoomla.com/blog/view/294-fixing-the-joomla-340-extensions-installer-bug.html
Hi all,
Yes, we have found that this is joomla issue too.
https://github.com/joomla/joomla-cms/pull/6180
Please use FTP installation method until joomla developers update joomla.
Edwin,
... i can not edit the template directly. I get all kinds of error messages
What exactly error messages?
I'm finding that with joomla 3.4 and themler that the pages aren't showing.
So basically no content from joomla is showing anymore on the themler template page when editing. . I am using a local host though haven't checked on server yet.
I'm finding that with joomla 3.4 and themler that the pages aren't showing. So basically no content from joomla is showing anymore on the themler template page when editing. . I am using a local host though haven't checked on server yet.David,
That's strange. Is it new Joomla or upgraded? Are you sure that you have appropriate content to show in Themler (Post, Page, Blog, etc)?
Could you please check this on the hosted Joomla. If the issue is reproducible please create a new Private topic and provide us with an access to the Joomla admin panel.
I've tested Themler theme on my local Joomla 3.4 (upgraded from 3.3.6) and everything is ok.
