How to remove the phone version like in Artister
How to remove the phone version like in ArtisterHow to remove the phone version like in Artister
How to remove the phone version like in ArtisterHi,
There is no possibility to switch off the responsive design in Themler.
why not? i payed for the program so if my client don't wont that why can't i disable it? S how can i tell them i cant do that? think of adding that option because some webs cant work on that kind a option so try this one on your phone so u can see how it looks because when i make tables on a article and want to look on them on my phone it looks like nothing. http://www.zuc-ls.hr/index.php/dokumenti.html
why not? i payed for the program so if my client don't wont that why can't i disable it? S how can i tell them i cant do that? think of adding that option because some webs cant work on that kind a option so try this one on your phone so u can see how it looks because when i make tables on a article and want to look on them on my phone it looks like nothing. http://www.zuc-ls.hr/index.php/dokumenti.htmlOr just add some plugin that tables can follow desktop to phone
Or just add some plugin that tables can follow desktop to phoneHi,
Themler is based on the Bootstrap and it is the modern technology that is a must-have nowadays. You can not simply switch it off.
If the only issue is with the tables, try setting the table width to 100%.
Also you can consider using DIV layout instead of tables.
