WordPress sub-menu items split in 2 columns. The easy way.
Ludwig
Ludwig posted this 19 May 2016
Can somebody tell me, why this does't work in Themler?
http://www.prowebdesign.ro/wordpress-sub-menu-items-split-in-2-columns-the-easy-way/
I also tryed different Plugins for Megamenu in WP. They don' work with themeler neither...
I just need one submenu with two columns, this can't be so difficult ...
Has nobody an idea?
Hoping for answers soon!
Tobi
Can somebody tell me, why this does't work in Themler? http://www.prowebdesign.ro/wordpress-sub-menu-items-split-in-2-columns-the-easy-way/ I also tryed different Plugins for Megamenu in WP. They don' work with themeler neither... I just need one submenu with two columns, this can't be so difficult ... Has nobody an idea? Hoping for answers soon! Tobi
Support Team posted this 20 May 2016
Unfortunately Themler does not have a megamenu feature now, but it is in our wishlist. You say that you have tried some plug-ins and they do not work/ Have you tried to position them in the different module position that is not a Themler menu position?
Hi, Unfortunately Themler does not have a megamenu feature now, but it is in our wishlist. You say that you have tried some plug-ins and they do not work/ Have you tried to position them in the different module position that is not a Themler menu position? Sincerely, Hella
Ludwig
Ludwig posted this 20 May 2016
Dear Hella,
I know that you have megamenu on your whishlist, but already since almost 2 years.... ;-)
Can you explain what you mean with "Have you tried to position them in the different module position that is not a Themler menu position?"
I tryed different plugins, some of them should work straight on the menu, some of them should work in an widget-aeria, but both are not realy working....
Sincerly Tobi
Dear Hella, I know that you have megamenu on your whishlist, but already since almost 2 years.... ;-) Can you explain what you mean with "Have you tried to position them in the different module position that is not a Themler menu position?" I tryed different plugins, some of them should work straight on the menu, some of them should work in an widget-aeria, but both are not realy working.... Sincerly Tobi
Please add "joomla position" content (Insert tab >> more) and put your third-party menu module into this module position. Please note that Themler theme will not affect the style of this menu except some general global styles.
Hi, Please add "joomla position" content (Insert tab >> more) and put your third-party menu module into this module position. Please note that Themler theme will not affect the style of this menu except some general global styles. Thank you, Olivia
Ludwig
Hi!
And this will work then in wordpress?
Thank you, Tobi
Hi! And this will work then in wordpress? Thank you, Tobi
WP theme is "WP widget area control". which works in the same way.
Also Themler theme includes "Use not stylized menu" option under the Appearance >> Theme Options to resolve conflicts between Themler menu and menu plug-ins which can work with native WP menu object. This option may be helpful in your case.
Hi, WP theme is "WP widget area control". which works in the same way. Also Themler theme includes "Use not stylized menu" option under the Appearance >> Theme Options to resolve conflicts between Themler menu and menu plug-ins which can work with native WP menu object. This option may be helpful in your case. Thank you, Olivia
Ludwig
Oh this sounds very good! ♥
I guess I'm actually pretty familar with themler but where can I find this theme-options?
Oh this sounds very good! ♥ I guess I'm actually pretty familar with themler but where can I find this theme-options?
That option is available within WP admin panel, not in Themler.
Hi, That option is available within WP admin panel, not in Themler. Sincerely, Hella
