Moving Themler to Another Computer
david157
david157 posted this 20 May 2016
I thought that I should let everybody know that there may be a big problem with Themler if it ever crashes, or if you want to upgrade your computer.
The scenario I had was that Themler would not start. I ended up having to re-install it and although I eventually got back my template files, all of the Joomla data (articles, menus etc.) had been lost.
I also tried installing Themler on another computer, moved over all of the files but had the same issue - templates there but no Joomla data.
Although support has tried helping me out, there doesn't seem to be a solution.
I did a backup using Akeeba as Themler suggested but what they don't tell you is that it is of no use if you want to install it into a new Themler installation: At least I have not shown how to do so if it is possible.
Although I think that Themler is a great product and support is normally pretty good, I'm now wary about using it in case I ever want to upgrade my computer.
If anybody out there has had a similar problem and has found a solution, I would be very grateful.
Many thanks, David
Hi I thought that I should let everybody know that there may be a big problem with Themler if it ever crashes, or if you want to upgrade your computer. The scenario I had was that Themler would not start. I ended up having to re-install it and although I eventually got back my template files, all of the Joomla data (articles, menus etc.) had been lost. I also tried installing Themler on another computer, moved over all of the files but had the same issue - templates there but no Joomla data. Although support has tried helping me out, there doesn't seem to be a solution. I did a backup using Akeeba as Themler suggested but what they don't tell you is that it is of no use if you want to install it into a **new** Themler installation: At least I have not shown how to do so if it is possible. Although I think that Themler is a great product and support is normally pretty good, I'm now wary about using it in case I ever want to upgrade my computer. If anybody out there has had a similar problem and has found a solution, I would be very grateful. Many thanks, David
12 Comments
Support Team posted this 24 May 2016
In general, you will face the same issue if you install xampp (wamp, lamp, etc) and CMS.
Themler Desktop is a package of Apache+MySQL server and CMS + theme with Themler.
There is no native feature for transferring full installation to the new computer because the Themler is a tool for designing themes. It's better to add and configure all content on the final server.
If you need constantly transfer local webserver between computers you can use xampp (wamp, lamp, etc) and CMS. You will not see the real difference between Desktop and your own local webserver.
Hi, In general, you will face the same issue if you install xampp (wamp, lamp, etc) and CMS. Themler Desktop is a package of Apache+MySQL server and CMS + theme with Themler. There is no native feature for transferring full installation to the new computer because the Themler is a tool for designing themes. It's better to add and configure all content on the final server. If you need constantly transfer local webserver between computers you can use xampp (wamp, lamp, etc) and CMS. You will not see the real difference between Desktop and your own local webserver. Thank you, Olivia
david157
david157 posted this 24 May 2016
Hi Olivia
I have just installed Xampp so I will try that out. If I can't manage to import/export databases with it, the problem will be that I will only be able to try out any data on the live server, which is not what I expect from Themler.
I am very surprised that there is no solution for transferring an existing joomla installation, together with all of the data and templates to another computer. Or am I missing something; is there a way to do this?
Best wishes, David
Hi Olivia I have just installed Xampp so I will try that out. If I *can't* manage to import/export databases with it, the problem will be that I will only be able to try out any data on the live server, which is not what I expect from Themler. I am very surprised that there is no solution for transferring an existing joomla installation, together with all of the data and templates to another computer. Or am I missing something; is there a way to do this? Best wishes, David
Support Team posted this 25 May 2016
As Olivia described above, Themler desktop application is a localhost server with the CMS and theme installed. So it works as the simple server. If you know how to transfer localhost from one computer to another, you can do that.
Whe workin on your XAMMP installation you can use the database tools that will export the site database and it will be available to import on the other server.
Also we are starting to implement the Export Content option for WP and Joomla sites so you will be able to export the cotent with the theme. Note, that it includes only pges and articles, modules, widgets and menus are not exported as the content.
Hi, As Olivia described above, Themler desktop application is a localhost server with the CMS and theme installed. So it works as the simple server. If you know how to transfer localhost from one computer to another, you can do that. Whe workin on your XAMMP installation you can use the database tools that will export the site database and it will be available to import on the other server. Also we are starting to implement the Export Content option for WP and Joomla sites so you will be able to export the cotent with the theme. Note, that it includes only pges and articles, modules, widgets and menus are not exported as the content. Sincerely, Hella
mgarcia
mgarcia posted this 30 November 2016
Im facing the same situation here.
I want to upgrade my PC. What files/databases should I need to move to the new one?
Please advice.
Basically I work with joomla and wordpress
Im facing the same situation here. I want to upgrade my PC. What files/databases should I need to move to the new one? Please advice. Basically I work with joomla and wordpress
Support Team posted this 02 December 2016
Hello Martin,
you may refer to Joomla docs
https://docs.joomla.org/Copying_a_Joomla_website
or looks for plugin which import/export Joomla sites
https://www.google.com/search?q=move+Joomla+site
Hello Martin, you may refer to Joomla docs https://docs.joomla.org/Copying_a_Joomla_website or looks for plugin which import/export Joomla sites https://www.google.com/search?q=move+Joomla+site Regards, Aileen
laurenjames9920
laurenjames9920 posted this 12 December 2024
To move Themler to another computer, install the software on the new device and copy the project files. If you need content generation support, try using an auto essay writer tool for efficiency. The assignment desk offers expert guidance to simplify tasks like these, ensuring seamless transitions and high-quality results. Stay organised and back up your data to avoid loss during the process.
To move Themler to another computer, install the software on the new device and copy the project files. If you need content generation support, try using an [auto essay writer][1] tool for efficiency. The assignment desk offers expert guidance to simplify tasks like these, ensuring seamless transitions and high-quality results. Stay organised and back up your data to avoid loss during the process. [1]: https://www.assignmentdesk.co.uk/ai-essay-writer
orangesharyl
orangesharyl posted this 13 December 2024
Hi David,
It sounds frustrating dealing with Themler crashing and losing Joomla data. While I love enjoying a classic game like Retro Bowl after a tech hassle, I recommend keeping regular backups to avoid future headaches. Have you tried reaching out on forums? Other users might have faced similar issues. Until you find a solution, maybe it’s a good time to enjoy some Retro Bowl to relieve the stress!
Hi David, It sounds frustrating dealing with Themler crashing and losing Joomla data. While I love enjoying a classic game like [Retro Bowl][1] after a tech hassle, I recommend keeping regular backups to avoid future headaches. Have you tried reaching out on forums? Other users might have faced similar issues. Until you find a solution, maybe it’s a good time to enjoy some Retro Bowl to relieve the stress! [1]: https://retrobowl-game.io
Free AI Tools
Free AI Tools posted this 14 December 2024
Free AI Tools
Latest Merch Deals
Remote Software Jobs
[Free AI Tools](http://troubleshoot.dev/) [Latest Merch Deals](http://latestmerch.com/) [Remote Software Jobs](http://programable.com/)
Free AI Tools
Free AI Tools
Latest Merch Deals
leafthatneverfall
leafthatneverfall posted this 18 December 2024
Thank you so much for the detailed tutorial. Let's discover a new way to explore Instagram with instagram viewer anonymous. This website offers a streamlined experience, allowing you to view trending posts, search by hashtag, and even follow specific accounts – all without creating an account. It's IG your way.
Thank you so much for the detailed tutorial. Let's discover a new way to explore Instagram with [instagram viewer anonymous][1]. This website offers a streamlined experience, allowing you to view trending posts, search by hashtag, and even follow specific accounts – all without creating an account. It's IG your way. [1]: https://picnok.com/
boyomi2747
boyomi2747 posted this 27 May 2026
Moving Themler to another computer can be tricky for a lot of people and there are a lot of people who are facing troubles. By using it we can troubleshoot the problems and it provides us the desired results. When I used quality industrial epoxy coating I saw it was providing the desired solutions.
Moving Themler to another computer can be tricky for a lot of people and there are a lot of people who are facing troubles. By using it we can troubleshoot the problems and it provides us the desired results. When I used [quality industrial epoxy coating][1] I saw it was providing the desired solutions. [1]: https://epoxyflooringsutherlandshire.com.au/services/industrial
lisachen1229
lisachen1229 posted this 27 May 2026
It’s really frustrating to lose Joomla data when transferring Themler between computers, and I often unwind by checking out fun guides on Horseywiki after troubleshooting these tricky tech problems.
It’s really frustrating to lose Joomla data when transferring Themler between computers, and I often unwind by checking out fun guides on [Horseywiki][1] after troubleshooting these tricky tech problems. [1]: https://horseygame.net/
