wordpress Themler background pattern
yyd
yyd posted this 22 May 2016
Does anyone know how to add some kind of texture such as dots or hatched lines, ets... on background. Here is an example background which I found a Themler section.
http://templates.themler.com/Themes/Detail/2822653/Container-in-Full-Width-Section-meow?containsInPage=True
As you see the section background on the address above, it colored in very tiny dots with light gray background. I believe dots are not png image data because the light gray color is chosen on themler and I tried to copy and paste style the background, I could duplicate exactly the same one.
Hi, Does anyone know how to add some kind of texture such as dots or hatched lines, ets... on background. Here is an example background which I found a Themler section. http://templates.themler.com/Themes/Detail/2822653/Container-in-Full-Width-Section-meow?containsInPage=True As you see the section background on the address above, it colored in very tiny dots with light gray background. I believe dots are not png image data because the light gray color is chosen on themler and I tried to copy and paste style the background, I could duplicate exactly the same one. regards,
Support Team posted this 24 May 2016
I have answered to another case with the same question.
Hi, I have answered to another case with the same question. Sincerely, Hella
yyd
yyd posted this 25 May 2016
Thanks. I got it.
Thanks. I got it.
Support Team posted this 25 May 2016
You are welcome.
You are welcome. Sincerely, Hella
