Edit theme prestashop
lg316317
lg316317 posted this 23 May 2016
Good day. I've attached a topic you would like to edit through your program. But it can not be exported. Is there any option to insert into your program? well thank you
Support Team posted this 24 May 2016
The attached theme does not look like a Themler theme. Only Themler themes can be imported into the Themler application (if exported before with the editor included).
Hi, The attached theme does not look like a Themler theme. Only Themler themes can be imported into the Themler application (if exported before with the editor included). Sincerely, Hella
