NextGEN for wordperss I have a double popup
specjalistawww.pl
specjalistawww.pl posted this 24 May 2016
how to disable popup for images in the template?
After installing the plugin NextGEN for wordperss I have a double popup.
thank
Hello, how to disable popup for images in the template? After installing the plugin NextGEN for wordperss I have a double popup. thank
Support Team posted this 24 May 2016
Open the appropriate template in Themler, navigate to the Posts control to see its options in the top ribbon and under the Post Content drop down there will be an option to disable the lightbox.
Hi, Open the appropriate template in Themler, navigate to the Posts control to see its options in the top ribbon and under the Post Content drop down there will be an option to disable the lightbox. Sincerely, Hella
mgarcia
mgarcia posted this 26 May 2016
I have the same issue, the "Image Lightbox" selector was disabled by default.
If you click on the image you can see the dark screen,
http://www.angeldavid.pe/exteriores/
Please help
Martin
Hello, I have the same issue, the "Image Lightbox" selector was disabled by default. !Captura.PNG! If you click on the image you can see the dark screen, http://www.angeldavid.pe/exteriores/ Please help Martin
Support Team posted this 30 May 2016
Hi Martin,
Please try to add the following code to your Themler Settings - Additional CSS:
.bd-lightbox, .lightbox, .bd-lightbox .lightbox-image {
    cursor: default;
    display: none;
Ivan
Hi Martin, Please try to add the following code to your Themler Settings - Additional CSS: .bd-lightbox, .lightbox, .bd-lightbox .lightbox-image { cursor: default; display: none; } Thanks, Ivan
mgarcia
mgarcia posted this 02 June 2016
Hi Ivan,
This solved the problem,
I added to the Additional CSS settings.
Thanks for the help!
Martin
Hi Ivan, This solved the problem, I added to the Additional CSS settings. Thanks for the help! Martin
Support Team posted this 04 June 2016
Hello Martin,
you're welcome, Let us know if you have additional questions
Hello Martin, you're welcome, Let us know if you have additional questions Regards, Aileen
