vertical menu in joomla
foffi.alessandro
foffi.alessandro posted this 25 May 2016
Hi I created menu in the back end and I followed all the steps for the vertical menu but I doesn't work. I'm working from desktop application
Support Team posted this 25 May 2016
It looks like the menu in your theme is a horizontal menu and not a vertical one.
Please note that you do not need to add any extra control in Themler for it. It is output with a module in the module position specified.
Also make sure you have specified " vmenu" Module Class Suffix (with a leading space) under the Advanced Options of the chosen Menu Module.
After this Refresh Content in Themler.
Let us know if the issue is still present.
Hello, It looks like the menu in your theme is a horizontal menu and not a vertical one. Please note that you do not need to add any extra control in Themler for it. It is output with a module in the module position specified. Also make sure you have specified **" vmenu"** Module Class Suffix (with a leading space) under the Advanced Options of the chosen Menu Module. After this Refresh Content in Themler. Let us know if the issue is still present. Sincerely, Nettie, BillionDigital Team
foffi.alessandro
Thank you. Solved!!
Thank you. Solved!!
