no longer appear Articles
criasara
criasara posted this 25 May 2016
I can no longer bring up articles from joomla. If I modify a page from the menu, the change goes on all pages except the home page. How can I do?
Support Team posted this 26 May 2016
Could you please describe the issue in more details? I assume that you are making changes to a Page or Post template, so these changes are reflected on all single article items using this template.
If you would like the changes to be reflected in a specific article only, please edit article content in Joomla admin or using Themler content editor.
Hello, Could you please describe the issue in more details? I assume that you are making changes to a Page or Post template, so these changes are reflected on all single article items using this template. If you would like the changes to be reflected in a specific article only, please edit article content in Joomla admin or using Themler content editor. Sincerely, Nettie, BillionDigital Team
criasara
criasara posted this 26 May 2016
the site is http://collage.it/collage/ whenever page change to make a change, through themler, the changes are also on all other pages. If I try to write something using Joomla, the page is blank How do I do?
Looks like you are adding the controls within the template ad not the Content area. Template is used for all pages of the same type so that's why your content appears on all of them. Add controls inside the CMS Cotent area marked with green. Check that the CMS Content is enabled under the Layout >> Content and Sidebars tab.
Hi, Looks like you are adding the controls within the template ad not the Content area. Template is used for all pages of the same type so that's why your content appears on all of them. Add controls inside the CMS Cotent area marked with green. Check that the CMS Content is enabled under the Layout >> Content and Sidebars tab. Sincerely, Hella
