Hope you can help me. I have a site that is using an extension RSDIRECTORY.
There is a link in it that links to a modal form.
The send message button on this page. Image attached.
http://bellbowrieproperties.com.au/buy/20-over-55-enjoy-the-lifestyle
I can't get the form to show.
I asked the RSJOOML.com guys about it and the gave me the reason below.
"Regarding the frontend issue you have described, please note that this is caused by the fact that your template loads Bootstrap 3.x:
http://bellbowrieproperties.com.au/templates/jwbellbowriebd/css/bootstrap.css
and not Bootstrap 2.3.2 as the Joomla! standard. RSDirectory! as well as our other extensions have been designed by following the Joomla! standard and in order the component to work properly, we recommend using Bootstrap 2.3.2.
Please contact your template developer directly regarding this matter, they should be able to provide assistance."
Is there anything that can be done to help with this issue?
Thanks David
Hi Hope you can help me. I have a site that is using an extension RSDIRECTORY. There is a link in it that links to a modal form. The send message button on this page. Image attached. http://bellbowrieproperties.com.au/buy/20-over-55-enjoy-the-lifestyle I can't get the form to show. I asked the RSJOOML.com guys about it and the gave me the reason below. "Regarding the frontend issue you have described, please note that this is caused by the fact that your template loads Bootstrap 3.x: http://bellbowrieproperties.com.au/templates/jwbellbowriebd/css/bootstrap.css and not Bootstrap 2.3.2 as the Joomla! standard. RSDirectory! as well as our other extensions have been designed by following the Joomla! standard and in order the component to work properly, we recommend using Bootstrap 2.3.2. Please contact your template developer directly regarding this matter, they should be able to provide assistance." Is there anything that can be done to help with this issue? Thanks David
