bug on menu wordpress (smartphone) - themler 301
BORN TO BE WEB
BORN TO BE WEB posted this 26 May 2016
on all my sites (WordPress), I have a menu problem. the menu does not unfold but reload the page. the problem only occurs on smartphone
Hi, on all my sites (WordPress), I have a menu problem. the menu does not unfold but reload the page. the problem only occurs on smartphone
9 Comments
BORN TO BE WEB
BORN TO BE WEB posted this 27 May 2016
idem in the search bar.... (PC, Tablet, smartphone)
BORN TO BE WEB
BORN TO BE WEB posted this 28 May 2016
OK... Setting theme > to take off "Make the header clickable"
he had to activate with the latest version 301 ...
OK... Setting theme > to take off "Make the header clickable" he had to activate with the latest version 301 ...
Support Team posted this 28 May 2016
I'm sorry but the issue is not quite clear for me.
Could you please provide more detailed description and link to your site?
Hello, I'm sorry but the issue is not quite clear for me. Could you please provide more detailed description and link to your site? Regards, Aileen
BORN TO BE WEB
To detail this is the header that was active
I corrected the concern by uncheck "Make the header clickable" (See screenshot)
the activation of the head is made with themler 301. I did not have this before with themler 295
To detail this is the header that was active I corrected the concern by uncheck "Make the header clickable" (See screenshot) the activation of the head is made with themler 301. I did not have this before with themler 295
Support Team posted this 30 May 2016
the issue is still not quite clear:
do you mean that after Themler update you cannot open access the submenu items? Or what?
Also please provide link to the page which demonstrates the issue
Hello, the issue is still not quite clear: do you mean that after Themler update you cannot open access the submenu items? Or what? Also please provide link to the page which demonstrates the issue Regards, Aileen
BORN TO BE WEB
BORN TO BE WEB posted this 31 May 2016
Yes, after the update, themler 301 activated "
Make the header clickable "in the theme options. I just turn it on https://www.corentine.net/.
You can test by doing a search bar in the header.
Hi, Yes, after the update, themler 301 activated " Make the header clickable "in the theme options. I just turn it on https://www.corentine.net/. You can test by doing a search bar in the header.
Support Team posted this 31 May 2016
Thanks for details, I could reproduce the issue and have forwarded it to our developers for investigation.
Hello, Thanks for details, I could reproduce the issue and have forwarded it to our developers for investigation. Sincerely, Nettie, BillionDigital Team
Support Team posted this 01 June 2016
The issue is fixed, and the fix will be included in the next Themler udpate. Most probably, in a Hotfix update.
Hello, The issue is fixed, and the fix will be included in the next Themler udpate. Most probably, in a Hotfix update. Sincerely, Nettie, BillionDigital Team
BORN TO BE WEB
BORN TO BE WEB posted this 01 June 2016
OK, thank you
OK, thank you
