Themler won't even open the only thing that comes up is the diagnostic tool. I've tried uninstalling and reinstalling but it doesn't help.
Please wait...Themler Diagnostics Log
Please create a new support topic at 'http://answers.themler.com' and attach this log to your ticket.
INFO:Version files finded:
INFO: C:\PROGRA~3\Themler\1.0.292.14.ver
INFO: C:\PROGRA~3\Themler\1.0.295.865.ver
INFO:Check free disk space...
INFO:Check Services...
ERROR:Apache service isn't started
INFO:Check Files...
ERROR:Can't find path C:\PROGRA~3\Themler\db_data (DB_DATA_DIR)
INFO:Check HTTP Server...
INFO:Check url for C:\PROGRA~3\Themler\hd_data\themler_992552508
INFO: Check is url available: http://localhost:12080/themler_992552508/joomla
ERROR:HTTP request to 'http://localhost:12080/themler_992552508/joomla' throw error:'Unable to connect to the remote server'
INFO: Check is url available: http://localhost:12080/themler_992552508/prestashop
ERROR:HTTP request to 'http://localhost:12080/themler_992552508/prestashop' throw error:'Unable to connect to the remote server'
INFO:Check INI Files...
INFO:No errors!
======== Content of file C:\Program Files (x86)\Themler\bin_logs\bat_exec.log ========
Program files detected C:\Program Files (x86)
Must be on program files\themler\bin
Volume in drive C is OS
Volume Serial Number is 9821-E663
Directory of C:\Program Files (x86)\Themler\bin
05/25/2016 10:10 PM <dir> .
05/25/2016 10:10 PM <dir> ..
05/25/2016 10:10 PM <dir> 7zip
05/25/2016 10:10 PM <dir> apache
05/25/2016 10:10 PM <dir> diagnostics
09/04/2015 02:08 AM 1,400 install-apache.bat
01/22/2016 11:04 AM 2,670 install-mysql.bat
05/25/2016 10:10 PM <dir> mysql
05/25/2016 10:11 PM <dir> php
08/03/2015 07:48 AM 1,711 uninstall-apache.bat
08/03/2015 07:48 AM 1,679 uninstall-mysql.bat
05/25/2016 10:10 PM <dir> _logs
</dir></dir></dir></dir></dir></dir></dir></dir> 4 File(s) 7,460 bytes
8 Dir(s) 393,297,784,832 bytes free
creating logs just in case
A subdirectory or file C:\ProgramData\Themler already exists.
8 Dir(s) 393,297,707,008 bytes free
======== End of file C:\Program Files (x86)\Themler\bin_logs\bat_exec.log ========
ERROR:Unable to find file C:\ProgramData\Themler\logs\Themler_vbs.log
======== Content of file C:\Users\keysha\AppData\Local\Themler\Themler_vbs.log ========
Log for USER - keysha
Log file path - C:\Users\keysha\AppData\Local\Themler\Themler_vbs.log
Self path = C:\PROGRA~2\Themler\Themler.vbs
Bin dir = C:\PROGRA~2\Themler\bin\
Flag isInstallation = False
Program Files 86 folder = C:\Program Files (x86)
Application Data folder = C:\ProgramData
Local Data folder = C:\Users\keysha\AppData\Local
Browser been started at "C:\PROGRA~2\Google\Chrome\APPLIC~1\chrome.exe" --start-maximized --disable-extensions --disable-translate --enable-file-cookies --no-default-browser-check --user-data-dir="C:\Users\keysha\AppData\Local\Themler\ChromeData" --app=
Start url is http://127.0.0.1:12080/startup.php?suffix=_992552508&browser=1
======== End of file C:\Users\keysha\AppData\Local\Themler\Themler_vbs.log ========
ERROR:Unable to find file C:\ProgramData\Themler\logs\startup.php.log
ERROR:Unable to find file C:\ProgramData\Themler\logs\apache\error.log
ERROR:Unable to find file C:\ProgramData\Themler\logs\apache\access.log
ERROR:Unable to find file C:\ProgramData\Themler\logs\mysql\error.log
======== Content of file C:\Users\keysha\AppData\Local\Temp\themler_install.log ========
Starting onInit...
Calculating user folders for install...
Users folder for install calculated
onInit finished...
Starting main...
Copying cms data...
CMS data copied
Copying rest of files...
Rest of files copied
Copying dumps...
Dumps copied
Main finished
Adding firewall rules...
Firewall rules added
Replacing config files...
Config files replaced
Installing MySql...
MySql installed
Installing apache service...
Apache service installed
Creating link and icons...
Icons and links created...
Opening control panel...
Control panel opened
Creating shorcut...
Shortcut created
======== End of file C:\Users\keysha\AppData\Local\Temp\themler_install.log ========
======== Content of chrome_debug.log ========
======== End of of chrome_debug.log ========
Themler won't even open the only thing that comes up is the diagnostic tool. I've tried uninstalling and reinstalling but it doesn't help. Please wait...Themler Diagnostics Log Please create a new support topic at 'http://answers.themler.com' and attach this log to your ticket. INFO:Version files finded: INFO: C:\PROGRA~3\Themler\1.0.292.14.ver INFO: C:\PROGRA~3\Themler\1.0.295.865.ver INFO:Check free disk space... INFO:Check Services... ERROR:Apache service isn't started INFO:Check Files... ERROR:Can't find path C:\PROGRA~3\Themler\db_data (DB_DATA_DIR) INFO:Check HTTP Server... INFO:Check url for C:\PROGRA~3\Themler\hd_data\themler_992552508 INFO: Check is url available: http://localhost:12080/themler_992552508/joomla ERROR:HTTP request to 'http://localhost:12080/themler_992552508/joomla' throw error:'Unable to connect to the remote server' INFO: Check is url available: http://localhost:12080/themler_992552508/prestashop ERROR:HTTP request to 'http://localhost:12080/themler_992552508/prestashop' throw error:'Unable to connect to the remote server' INFO:Check INI Files... INFO:No errors! ======== Content of file C:\Program Files (x86)\Themler\bin\_logs\bat_exec.log ======== Program files detected C:\Program Files (x86) Must be on program files\themler\bin Volume in drive C is OS Volume Serial Number is 9821-E663 Directory of C:\Program Files (x86)\Themler\bin 05/25/2016 10:10 PM <dir> . 05/25/2016 10:10 PM <dir> .. 05/25/2016 10:10 PM <dir> 7zip 05/25/2016 10:10 PM <dir> apache 05/25/2016 10:10 PM <dir> diagnostics 09/04/2015 02:08 AM 1,400 install-apache.bat 01/22/2016 11:04 AM 2,670 install-mysql.bat 05/25/2016 10:10 PM <dir> mysql 05/25/2016 10:11 PM <dir> php 08/03/2015 07:48 AM 1,711 uninstall-apache.bat 08/03/2015 07:48 AM 1,679 uninstall-mysql.bat 05/25/2016 10:10 PM <dir> _logs </dir></dir></dir></dir></dir></dir></dir></dir> 4 File(s) 7,460 bytes 8 Dir(s) 393,297,784,832 bytes free creating logs just in case A subdirectory or file C:\ProgramData\Themler already exists. A subdirectory or file C:\Pr Program files detected C:\Program Files (x86) Must be on program files\themler\bin Volume in drive C is OS Volume Serial Number is 9821-E663 Directory of C:\Program Files (x86)\Themler\bin 05/25/2016 10:10 PM <dir> . 05/25/2016 10:10 PM <dir> .. 05/25/2016 10:10 PM <dir> 7zip 05/25/2016 10:10 PM <dir> apache 05/25/2016 10:10 PM <dir> diagnostics 09/04/2015 02:08 AM 1,400 install-apache.bat 01/22/2016 11:04 AM 2,670 install-mysql.bat 05/25/2016 10:10 PM <dir> mysql 05/25/2016 10:11 PM <dir> php 08/03/2015 07:48 AM 1,711 uninstall-apache.bat 08/03/2015 07:48 AM 1,679 uninstall-mysql.bat 05/25/2016 10:10 PM <dir> _logs </dir></dir></dir></dir></dir></dir></dir></dir> 4 File(s) 7,460 bytes 8 Dir(s) 393,297,707,008 bytes free creating logs just in case A subdirectory or file C:\ProgramData\Themler already exists. A subdirectory or file C:\Pr ======== End of file C:\Program Files (x86)\Themler\bin\_logs\bat_exec.log ======== ERROR:Unable to find file C:\ProgramData\Themler\logs\Themler_vbs.log ======== Content of file C:\Users\keysha\AppData\Local\Themler\Themler_vbs.log ======== ### Log for USER - keysha ### Log file path - C:\Users\keysha\AppData\Local\Themler\Themler_vbs.log Self path = C:\PROGRA~2\Themler\Themler.vbs Bin dir = C:\PROGRA~2\Themler\bin\ Flag isInstallation = False Program Files 86 folder = C:\Program Files (x86) Application Data folder = C:\ProgramData Local Data folder = C:\Users\keysha\AppData\Local Browser been started at "C:\PROGRA~2\Google\Chrome\APPLIC~1\chrome.exe" --start-maximized --disable-extensions --disable-translate --enable-file-cookies --no-default-browser-check --user-data-dir="C:\Users\keysha\AppData\Local\Themler\ChromeData" --app= Start url is http://127.0.0.1:12080/startup.php?suffix=_992552508&browser=1 ======== End of file C:\Users\keysha\AppData\Local\Themler\Themler_vbs.log ======== ERROR:Unable to find file C:\ProgramData\Themler\logs\startup.php.log ERROR:Unable to find file C:\ProgramData\Themler\logs\apache\error.log ERROR:Unable to find file C:\ProgramData\Themler\logs\apache\access.log ERROR:Unable to find file C:\ProgramData\Themler\logs\mysql\error.log ======== Content of file C:\Users\keysha\AppData\Local\Temp\themler_install.log ======== Starting onInit... Calculating user folders for install... Users folder for install calculated onInit finished... Starting main... Copying cms data... CMS data copied Copying rest of files... Rest of files copied Copying dumps... Dumps copied Main finished Adding firewall rules... Firewall rules added Replacing config files... Config files replaced Installing MySql... MySql installed Installing apache service... Apache service installed Creating link and icons... Icons and links created... Opening control panel... Control panel opened Creating shorcut... Shortcut created ======== End of file C:\Users\keysha\AppData\Local\Temp\themler_install.log ======== ======== Content of chrome_debug.log ======== ======== End of of chrome_debug.log ========
