bloc social in Header?
WALLOON
WALLOON posted this 30 May 2016
Social icon ok in Header... like my facebook.
Bloc social...
it is active in the module and it is graffer in the header (and footer)
It appears in the footer, but not in the header, why?
Thank you for your help
http://lesabrisdejardin.be/index.php
Social icon ok in Header... like my facebook. Bloc social... it is active in the module and it is graffer in the header (and footer) It appears in the footer, but not in the header, why? Thank you for your help http://lesabrisdejardin.be/index.php
Support Team posted this 30 May 2016
Sorry, the question is not clear. I can see the Facebook icon and link in the header. Maybe some screen shots and detailed explanation of what you are trying to achieve will be helpful.
Hi, Sorry, the question is not clear. I can see the Facebook icon and link in the header. Maybe some screen shots and detailed explanation of what you are trying to achieve will be helpful. Sincerely, Hella
WALLOON
image ;)
!admin-prestashop-bloc-social.jpg! !bloc-social-prestashop.jpg! image ;)
Support Team posted this 31 May 2016
The issue is that in Themler Footer we use Prestashop displayFooter hook and it displays the modules added to that hook from the Prestashop admin. You have a Block Social module in that hook, that's correct.
As seen on your screen shot: This hook adds additional elements in the head section of your pages (head section of html). That is about Header hook. In the Themler Header you can use Themler controls and that is not a hook, that is a part of the theme.
As a solution, you can add the Block Social module in the displayTop hook inside Prestashop admin and add the HookTop control inside Themler from the Insert menu. That will require some additional settings or CSS code. maybe also remove unnecessary module positions from that hook.
Hi, The issue is that in Themler Footer we use Prestashop displayFooter hook and it displays the modules added to that hook from the Prestashop admin. You have a Block Social module in that hook, that's correct. As seen on your screen shot: This hook adds additional elements in the head section of your pages (head section of html). That is about Header hook. In the Themler Header you can use Themler controls and that is not a hook, that is a part of the theme. As a solution, you can add the Block Social module in the displayTop hook inside Prestashop admin and add the HookTop control inside Themler from the Insert menu. That will require some additional settings or CSS code. maybe also remove unnecessary module positions from that hook. Sincerely, Hella
