I can't iadd a Small Picture (Favicon)
web.SSMB.pe
web.SSMB.pe posted this 30 May 2016
Hi. I have this problem. When I go to Home - Settings - General - Small Picture (Favicon) - From file... nothing happens. Some months ago, I could add a images as a Favicon. Is it this a bug? Can you fix it? Thanks.
23 Comments
Marco
Marco posted this 30 May 2016
If just created a new website WITH a favicon (upload .png via themler).
Works perfectly.
Try with not bigger then 32x32px - should work.
If just created a new website WITH a favicon (upload .png via themler). Works perfectly. Try with not bigger then 32x32px - should work.
Support Team posted this 31 May 2016
Please attach the exact file you are trying to upload as the favicon.
Hi, Please attach the exact file you are trying to upload as the favicon. Sincerely, Hella
bl.domains@betternoi.com
bl.domains@betternoi.com posted this 31 May 2016
I'm having the same problems loading a file type ICO which I already had uploaded to other sites before the update. I went back and opened an existing site and tried uploading the same file and it fails with "Warning, We're sorry. We cant open this file type". I need to upload ICO type since it has multiple file sizes for desktop and mobile bookmarking. Thanks
web.SSMB.pe
web.SSMB.pe posted this 31 May 2016
My problem is when I try to click on "From file...". It suppose it will open a window where I select the file, right? Ok, that's the problem: nothing happens. no window is open, so I can't select a file.
Support Team posted this 01 June 2016
web.SSMB.pe,
walter.a.britton,
I couldn't reproduce the issue with the .ico icon with Themler online in Chrome - added the icon From File in .ico format and uploaded it successfully. Are the issues present for you only in Themler for Windows or Themler for Mac, or with some specific theme, with some specific browser?
Also please try temporary disabling browser add-ons and try with a different browser.
**web.SSMB.pe**, **walter.a.britton**, I couldn't reproduce the issue with the .ico icon with Themler online in Chrome - added the icon From File in .ico format and uploaded it successfully. Are the issues present for you only in Themler for Windows or Themler for Mac, or with some specific theme, with some specific browser? Also please try temporary disabling browser add-ons and try with a different browser. Please let us know the result. Sincerely, Nettie, BillionDigital Team
Vi ER konsulenter
Vi ER konsulenter posted this 15 January 2017
I have the same problem.
I have a Windows pc with Google Chrome. I go to home -> settings. Click on the Add favicon thumbnail and select 'from file' and the popup screen to upload the image does not appear. This also doesn't work in Firefox.
I tried uploading the picture through the option 'url'. The uploading worked, but the favicon is not shown.
I have the same problem. I have a Windows pc with Google Chrome. I go to home -> settings. Click on the Add favicon thumbnail and select 'from file' and the popup screen to upload the image does not appear. This also doesn't work in Firefox. I tried uploading the picture through the option 'url'. The uploading worked, but the favicon is not shown.
Support Team posted this 16 January 2017
Have you tried to edit the theme from another computer? Also make sure that your favicon is an .ico file with 32*32 resolution.
Hi, Have you tried to edit the theme from another computer? Also make sure that your favicon is an .ico file with 32*32 resolution. Sincerely, Hella
shopmods
shopmods posted this 05 February 2017
Same problem. No file upload appears. It worked with a previous version of Themler 100%. Chrome/FF on Win Server 2012 R2.
Support Team posted this 06 February 2017
Please create a private topic and provide an access to your site and attach the favicon file.
Hi, Please create a private topic and provide an access to your site and attach the favicon file. Sincerely, Hella
oceanite
oceanite posted this 03 April 2017
I have the same problem, I can not attach photo.
I can not remove link.
Please help
Hello, I have the same problem, I can not attach photo. I can not remove link. Please help Regards
Support Team posted this 03 April 2017
oceanite,
Do you work in Themler for Windows, Themler for Mac, or on your live host? Did you try a different browser? How exactly are you adding the favicon - from file?
**oceanite**, Do you work in Themler for Windows, Themler for Mac, or on your live host? Did you try a different browser? How exactly are you adding the favicon - from file? Sincerely, Nettie, BillionDigital Team
oceanite
Hi Nettie,
Live host in wordpress.
Adding favicon with URL in Themler, now I want to remove url but themler will not let me.
Hi Nettie, Live host in wordpress. Adding favicon with URL in Themler, now I want to remove url but themler will not let me. Thanks Regards
oceanite,
Could you please create a new private topic and provide temporary access to your website for investigation?
**oceanite**, Could you please create a new private topic and provide temporary access to your website for investigation? Sincerely, Nettie, BillionDigital Team
oceanite
oceanite posted this 04 April 2017
I do not give you access to my website, there are more people with the same problem, there is the same problem with the version destock, I can not attach photo and I can not remove link.
I do not give you access to my website, there are more people with the same problem, there is the same problem with the version destock, I can not attach photo and I can not remove link. Thanks Regards
Support Team posted this 04 April 2017
We are sorry for the issue. The issue with the favicon not working from URL is forwarded to our developers. I would recommend you to try temporarily using the option "From File", it is not necessary to remove the URL inserted previously - it will be overwritten.
Hello, We are sorry for the issue. The issue with the favicon not working from URL is forwarded to our developers. I would recommend you to try temporarily using the option "From File", it is not necessary to remove the URL inserted previously - it will be overwritten. Sincerely, Nettie, BillionDigital Team
oceanite
Not possible "from file", themler not work.
Support Team posted this 05 April 2017
I cannot reproduce the issue with the favicon From File with the latest Themler version, the favicon is applied correctly. If you would not prefer to provide access to your website, could you probably export the theme and attach the image for the favicon, so that we could test it on our end? Please attach them in a new private case.
Hello, I cannot reproduce the issue with the favicon From File with the latest Themler version, the favicon is applied correctly. If you would not prefer to provide access to your website, could you probably export the theme and attach the image for the favicon, so that we could test it on our end? Please attach them in a new private case. Thank you, Nettie, BillionDigital Team
oceanite
oceanite posted this 05 April 2017
Hi Nettie,
I created a new theme in wordpress to test (destock and w7 64bits).
"From file" and "url" work, but I can not delete the url after adding it.
I hope this helps.
Hi Nettie, I created a new theme in wordpress to test (destock and w7 64bits). "From file" and "url" work, but I can not delete the url after adding it. I hope this helps. Thanks
Unfortunately there is no option to remove the image at this time. But you can change the icon to some default icon instead of removing.
Hi, Unfortunately there is no option to remove the image at this time. But you can change the icon to some default icon instead of removing. Thank you, Olivia
oceanite
I just want to remove the URL
> Hi, > > Unfortunately there is no option to remove the image at this time. But you can change the icon to some default icon instead of removing. > > Thank you, > Olivia I just want to remove the URL Thanks
