my question is about columns. Is it possible to set a hyperlink and a hover effect on a column?
Hello, my question is about columns. Is it possible to set a hyperlink and a hover effect on a column?Hello,
Hello, my question is about columns. Is it possible to set a hyperlink and a hover effect on a column?Hi,
You can use the available animations in the column or insert a Hover Box control with the size of the column. Also there is no direct option to link the whole column, you can do it with the help of other controls or custom code depending on what element you want to see in the column.
i have the same question and i didn't find the available animation in the column, (hyperlink, and hover effect).
Can you tell me how to do?
Do you have any plan to add this function?
thanks
As I mentioned in the post above, you can add the Hover Box control from the Insert tab inside the column.
