I'm using Themler for Windows.
If I change the sample data within a Joomla template that I have created (i.e. create menus, articles, page positions etc. within the sql database), presumably this data will be used an all future templates that I create and subsequently export.
But what happens when I update the template or Themler itself. Does the update overwrite the data I have created so that it gets back to the standard default Themler installation using the joomla_[numbers].sql database?
If it does, can I import my own database (using phpMyadmin that I have configured to work with Themler) and overwrite the joomla_[numbers].sql database so that I have my own data back?
Many thanks, David
Hi I'm using Themler for Windows. If I change the sample data within a Joomla template that I have created (i.e. create menus, articles, page positions etc. within the sql database), presumably this data will be used an all future templates that I create and subsequently export. But what happens when I update the template or Themler itself. Does the update overwrite the data I have created so that it gets back to the standard default Themler installation using the joomla_*[numbers]*.sql database? If it does, can I import my own database (using phpMyadmin that I have configured to work with Themler) and overwrite the joomla_*[numbers]*.sql database so that I have my own data back? Many thanks, David
