hi
i want to create 5 couloms in one row 20% each colum.
the program give me to chouse the % but not 20% there//
hi
Hi webcompanysale,
Solved in this forum post: http://answers.themler.com/questions/81857/5-columms-with-same-width
Follow my post, good luck
Hi webcompanysale, Solved in this forum post: http://answers.themler.com/questions/81857/5-columms-with-same-width Follow my post, good luckHi,
You can do it with the custom CSS. There is no possibility to do it directly in the application as we are using Bootstrap and Bootstrap is providing 12-grid layout that can not be equally divided into 5 parts.
Hi webcompanysale,
Follow this simple steps directly in Themler:
1.- Add this custom CSS to your template directly in Themler > Theme Settings > Additional CSS:
.col-xs-15,
.col-sm-15,
.col-md-15,
.col-lg-15 {
position: relative;
min-height: 1px;
padding-right: 10px;
padding-left: 10px;
.col-xs-15 {
width: 20%;
float: left;
@media (min-width: 768px) {
.col-sm-15 {
width: 20%;
float: left;
@media (min-width: 992px) {
.col-md-15 {
width: 20%;
float: left;
@media (min-width: 1200px) {
.col-lg-15 {
width: 20%;
float: left;
2.- Use the follow sample code in your Html or CMS template to create 5 columns row:
Add to each of 5 columns div this class > class="col-xs-12 col-sm-15 col-md-15 col-lg-15"
3.- Thats all!
Goog luck
Hi webcompanysale, Follow this simple steps directly in Themler: **1.- Add this custom CSS to your template directly in Themler > Theme Settings > Additional CSS:** .col-xs-15, .col-sm-15, .col-md-15, .col-lg-15 { position: relative; min-height: 1px; padding-right: 10px; padding-left: 10px; } .col-xs-15 { width: 20%; float: left; } @media (min-width: 768px) { .col-sm-15 { width: 20%; float: left; } } @media (min-width: 992px) { .col-md-15 { width: 20%; float: left; } } @media (min-width: 1200px) { .col-lg-15 { width: 20%; float: left; } } **2.- Use the follow sample code in your Html or CMS template to create 5 columns row:** Add to each of 5 columns div this class > ***class="col-xs-12 col-sm-15 col-md-15 col-lg-15"*** **3.- Thats all!** Goog luckLast edited 01 June 2016 by gcg
Sorry, i mean:
When you create a new row with Bootstrap class like its explained here: http://getbootstrap.com/css/#grid, in any column div add this class code: class="col-xs-12 col-sm-15 col-md-15 col-lg-15"
If you are using columns shortcodes of Themler, then this is not possible.
Sorry, i mean: When you create a new row with Bootstrap class like its explained here: http://getbootstrap.com/css/#grid, in any column div add this class code: ***class="col-xs-12 col-sm-15 col-md-15 col-lg-15"*** If you are using columns shortcodes of Themler, then this is not possible.Hi webcompanysale,
Yes, this custom CSS is added to Themler directly and you can use it to make this 5 columns design that you attach.
1.- You only have to copy/paste the CSS in Themler > Theme Settings > Additional CSS > Save the template > Export/Import.
2.- In your content sections, add a bootstrap row div with his inner 5 columns divs. In each of this 5 columns divs copy/paste this class: class="col-xs-12 col-sm-15 col-md-15 col-lg-15"
3.- With this steps, you will have 5 columns of 20% like your design, and only have to add the content of each column.
Better explained?
Hi webcompanysale, Yes, this custom CSS is added to Themler directly and you can use it to make this 5 columns design that you attach. 1.- You only have to copy/paste the CSS in Themler > Theme Settings > Additional CSS > Save the template > Export/Import. 2.- In your content sections, add a bootstrap row div with his inner 5 columns divs. In each of this 5 columns divs copy/paste this class: ***class="col-xs-12 col-sm-15 col-md-15 col-lg-15"*** 3.- With this steps, you will have 5 columns of 20% like your design, and only have to add the content of each column. Better explained?2.- Use the follow sample code in your Html or CMS template to create 5 columns row:
3.- Thats all!
Goog luck
where i can put custom class in themler to a clumn div?
> **2.- Use the follow sample code in your Html or CMS template to create 5 columns row:** > > Add to each of 5 columns div this class > ***class="col-xs-12 col-sm-15 col-md-15 col-lg-15"*** > > **3.- Thats all!** > > Goog luck where i can put custom class in themler to a clumn div?Last edited 10 October 2016 by Giuma
You will need to edit the content as the HTML Source.
