v301 crashes every time when I change the order of the pages by drag and drop. I use HTML5 template.
v301 crashes every time when I change the order of the pages by drag and drop. I use HTML5 template.Hello,
Thank you for reporting the issue. I could reproduce it and have forwarded it to our developers for investigation.
The issue is fixed, and the fix will be implemented in the next Themler update.
I am having the same problem and cannot finish the site I am working on. Can you please let me know when the next update will be released?
Yogi
Hello Yogi,
we expect it to be included into the next Themler update, but right now we cannot provide 100% guarantee.
Please watch the announcements
Most probably the fix will be implemented into the hotfix update, that is expected at the end of the week.
I can't submit new question on answers.themler.com portal. I always get error.possiblespam message.
I can't submit new question on answers.themler.com portal. I always get error.possiblespam message.Hello,
The issue may be related to the post text. Could you please try to put the same text in this topic or attach it as .txt, if it is not possible, so that we could check it?
Also please make sure to be logged in under the same account.
