Aileen,
The link you posted doesn't work, or is moved.
I'm having the same issue. Themler refuses to acknowledge the "posts" on the home page in WP Settings > Reading > Front Page Displays = Your latest posts.
Themler mandates that I use WP Settings > Reading > Front Page Displays = Static Page. I don't want a static page - I "want" the recent posts to appear on the home page.
WP then creates 2 "home" links.
The only way I could get it to come close to working is if I allowed the default "Hello World" post name to remain, and the link, regardless of what I name the link, takes me to "hello-world", which is what I want because posts will appear there.
If I use a static page, then the posts won't appear on the home page.
WordPress....wtf....
So what's the resolve? Themler only allows a static page to be the home page.
I "might" be able to create a work-around, but the breadcrumbs is also causing grief. There is no way to change the "Home" link in breadcrumbs to anything other than the link set in WP - Settings > General > Site URL
Even changing that won't help because it still won't effect the "Home" link in Themler.
Themler breadcrumb "Home" takes the URL from WP > Settings > General > WordPress Address (URL).
If you change the ... Site URL, that only confuses things.
WordPress allows the home page to be your recent posts. Themler does not.
This needs to be fixed.
Or, is there some "other" work-around of which I'm not aware?
I did see another post where someone was trying to show how to add some PHP to help. I "think" they were trying to say (very broken English and every time others asked for more details, the person posting the PHP help provided LESS information....) that if you add that code where the person states, then the static page will also show recent posts on the home page.
So I'm going to go back and read that encrypted post another 3 or 10 times to see if I can make sense of that.
http://answers.themler.com/questions/37596/wordpress-post-in-blog-post-in-home-page
Thanks.
Thomas
Aileen,
Thanks.
Thomas
