Calendar plugin for wordpress compatible with Themler themes
132werwer
132werwer posted this 09 June 2016
Hey, I need a calendar plugin for Wordpress which is compatible with Themler. Which one can you recommend?
I've tried "The Events Calendar" from Modern Tribe Inc. but it doesnt't work properly, does someone know a fix or another good calendar plugin which is similar like this?
Hey, I need a calendar plugin for Wordpress which is compatible with Themler. Which one can you recommend? I've tried "The Events Calendar" from Modern Tribe Inc. but it doesnt't work properly, does someone know a fix or another good calendar plugin which is similar like this?
Support Team posted this 14 June 2016
Hello Torsten,
in general we do not recommend any specific plugin.
As for Events Calendar plugin our developers have found a workaround for Event Calendar.
Please try to add the following piece of code to Themler Settings - CMS Code:
  function _tribe_events_after_the_grid() {
        echo '%%theme_more%%';
        add_filter('pre_option_theme_show_morelink', create_function('', 'return 0;'));
    add_action('tribe_events_after_the_grid', '_tribe_events_after_the_grid');
This should help.
Let us know the results.
Hello Torsten, in general we do not recommend any specific plugin. As for Events Calendar plugin our developers have found a workaround for Event Calendar. Please try to add the following piece of code to Themler Settings - CMS Code: function _tribe_events_after_the_grid() { echo '%%theme_more%%'; add_filter('pre_option_theme_show_morelink', create_function('', 'return 0;')); } add_action('tribe_events_after_the_grid', '_tribe_events_after_the_grid'); This should help. Let us know the results. regards, Aileen
132werwer
132werwer posted this 15 June 2016
Ah, Thanks, it helped me a lot.
simone.miotto
simone.miotto posted this 16 August 2016
Hello! Thanx a lot, this saved my day!
So i stuffed this fix as a plugin, may be easier to deploy and to switch on/off instead of merging the code in Themler. This is the first and very raw version but it works!
https://dl.dropboxusercontent.com/u/20846441/Tribe_events_themler_fix.zip
I made also a small plugin to order the events in the blog roll by date of publishing instead of by event's date
https://dl.dropboxusercontent.com/u/20846441/Tribe_events_by_creation_date.zip
Hope it will help! Enjoy!
Hello! Thanx a lot, this saved my day! So i stuffed this fix as a plugin, may be easier to deploy and to switch on/off instead of merging the code in Themler. This is the first and very raw version but it works! https://dl.dropboxusercontent.com/u/20846441/Tribe_events_themler_fix.zip I made also a small plugin to order the events in the blog roll by date of publishing instead of by event's date https://dl.dropboxusercontent.com/u/20846441/Tribe_events_by_creation_date.zip Hope it will help! Enjoy!
mbauer1
mbauer1 posted this 28 February 2017
Dear Simone, it seems as if I have the same problem with events calendar. Your plugin is no longer available. Could you provide the plugin again? Thanks alot.
Martin
Dear Simone, it seems as if I have the same problem with events calendar. Your plugin is no longer available. Could you provide the plugin again? Thanks alot. Martin
simone.miotto
simone.miotto posted this 28 February 2017
Sorry i forgot about them while working on dropbox and deleted...
Now i try to attach them directly into this thread
Sorry i forgot about them while working on dropbox and deleted... Now i try to attach them directly into this thread
alexarafatonline
alexarafatonline posted this 21 June 2025
I feel your pain! I struggled with calendar plugins too until I found one that just worked. While setting up my travel blog, I needed something reliable to showcase Norway’s 2025 holidays—like Labor Day (May 1st) and Ascension Day—so visitors could plan trips around festivals. I ended up using WP Events Manager—lightweight, Themler-friendly, and handles recurring dates perfectly. Bonus: It even imported my Norwegian weekly kalender CSV without a hitch! Maybe give it a try? (Pro tip: Check their demo to see if it fits your vibe before installing.)
I feel your pain! I struggled with calendar plugins too until I found one that just worked. While setting up my travel blog, I needed something reliable to showcase Norway’s 2025 holidays—like Labor Day (May 1st) and Ascension Day—so visitors could plan trips around festivals. I ended up using WP Events Manager—lightweight, Themler-friendly, and handles recurring dates perfectly. Bonus: It even imported my Norwegian weekly [kalender][1] CSV without a hitch! Maybe give it a try? (Pro tip: Check their demo to see if it fits your vibe before installing.) [1]: https://norskukekalender.com/
leadercompany606
leadercompany606 posted this 12 December 2025
კორპორატიული ლოგოს შექმნა აუცილებელია, რადგან ის ბრენდის იდენტობის მთავარი სიმბოლოა. სწორად დაგეგმილი ლოგო ეხმარება კომპანიას გამოიჩინოს საკუთარი უნიკალური სტილი, ჩამოაყალიბოს პირველი შთაბეჭდილება და მარტივად ამოიცნოს მომხმარებელმა. ლოგო ამყარებს კომპანიის სანდოობას, ზრდის ბრენდის ცნობადობას და ქმნის ვიზუალურ ერთიანობას ყველა მარკეტინგულ მასალაში — საიტიდან დაწყებული, სოციალური ქსელებითა და შეფუთვებით დასრულებული. ძლიერი ლოგო საბოლოოდ აძლიერებს ბრენდის იმიჯს და უწყობს ხელს მის განვითარებას.
კორპორატიული [ლოგოს შექმნა][1] აუცილებელია, რადგან ის ბრენდის იდენტობის მთავარი სიმბოლოა. სწორად დაგეგმილი ლოგო ეხმარება კომპანიას გამოიჩინოს საკუთარი უნიკალური სტილი, ჩამოაყალიბოს პირველი შთაბეჭდილება და მარტივად ამოიცნოს მომხმარებელმა. ლოგო ამყარებს კომპანიის სანდოობას, ზრდის ბრენდის ცნობადობას და ქმნის ვიზუალურ ერთიანობას ყველა მარკეტინგულ მასალაში — საიტიდან დაწყებული, სოციალური ქსელებითა და შეფუთვებით დასრულებული. ძლიერი ლოგო საბოლოოდ აძლიერებს ბრენდის იმიჯს და უწყობს ხელს მის განვითარებას. [1]: https://leadercompany.ge/
