Possible to replicate theme content across all pages?
chriscundy
chriscundy posted this 13 June 2016
Is it bossible to replicate theme content across all pages?
For example you will see the pink area on this site below the header and menu?
http://www.haywoodvillage.org.uk/v2/
I want to replicate this section so that others will also see this section on other pages such as:
http://www.haywoodvillage.org.uk/v2/community/
Is it bossible to replicate theme content across all pages? For example you will see the pink area on this site below the header and menu? http://www.haywoodvillage.org.uk/v2/ I want to replicate this section so that others will also see this section on other pages such as: http://www.haywoodvillage.org.uk/v2/community/
Support Team posted this 14 June 2016
Try to place that section inside Header area marked with orange. That area is shared through all the templates.
Hi, Try to place that section inside Header area marked with orange. That area is shared through all the templates. Sincerely, Hella
chriscundy
chriscundy posted this 14 June 2016
Good shout, I'll try this later.
Also on the homepage I have a side bar with login and new posts etc. Do I need to manually recreate this on each page??
Good shout, I'll try this later. Also on the homepage I have a side bar with login and new posts etc. Do I need to manually recreate this on each page??
Support Team posted this 15 June 2016
If you placed those widgets directly in the widget area and it is inside the orange Sidebar section, then those widgets will appear on all templates unless you disable the sidebar for the specific templates.
Hi, If you placed those widgets directly in the widget area and it is inside the orange Sidebar section, then those widgets will appear on all templates unless you disable the sidebar for the specific templates. Sincerely, Hella
