I'm struggling to add a vertical menu. I have a sidebar with Joomla position 'vmenu' in my template And it's showing the vertical menu, but there is no style/css aplied to it. Just letters. Im trying to follow the instructions in the Docs info: Styling for the Vertical Menu can be adjusted in PW >> Styles >> Vertical Menu. But I cant figure out what is meant with PW The changes I make following the path: DESIGN>>MORE STYLES>>VERTICAL MENU have no effect.
What am I doing wrong?
I'm struggling to add a vertical menu. I have a sidebar with Joomla position 'vmenu' in my template And it's showing the vertical menu, but there is no style/css aplied to it. Just letters. Im trying to follow the instructions in the Docs info: *Styling for the Vertical Menu can be adjusted in PW >> Styles >> Vertical Menu.* But I cant figure out what is meant with *PW* The changes I make following the path: DESIGN>>MORE STYLES>>VERTICAL MENU have no effect. What am I doing wrong?Last edited 15 June 2016 by hvandentol
