Wordpress and search when search is in the header of the theme
Marcus Anderson
Marcus Anderson posted this 18 June 2016
I've discovered when you put the search bar in the header and then select "make header clickable" in the wordpress options, the search becomes unusuable.
If you click in the search box the page will behave like the header was clicked.
So for example if you have "make header clickable" in the wordpress options and have it directing you to the site home page, when you click the search bar, the home page will reload.
Is there a workaround for this issue?
Hi, I've discovered when you put the search bar in the header and then select "make header clickable" in the wordpress options, the search becomes unusuable. If you click in the search box the page will behave like the header was clicked. So for example if you have "make header clickable" in the wordpress options and have it directing you to the site home page, when you click the search bar, the home page will reload. Is there a workaround for this issue?
Support Team posted this 20 June 2016
The issue is fixed, please try updating to the latest Beta version. You may need to check the box next to "Get Beta updates" in your profile to receive the Beta update notification. After installing the Beta update you may uncheck the box at any time.
Hello, The issue is fixed, please try updating to the latest Beta version. You may need to check the box next to "Get Beta updates" in your profile to receive the Beta update notification. After installing the Beta update you may uncheck the box at any time. Sincerely, Nettie, BillionDigital Team
