Add extra column to section
Seppe
Seppe posted this 20 June 2016
I've added the Four Columns With Header - Section calles "How much does it cost?"
It's the one with 4 columns in 4 different colors.
I want to add a 5th column, next to the red colomn.
But my Themler only add's a column above the plans, next to the header.
Isn't it possible to add more than 4 columns?
When I look at my website, after adding this section, it's already there, just like it's added.
How can I edit the text? am I obliged to edit the text in the theme? or can it be done through my CMS?
greetings
Seppe
I've added the Four Columns With Header - Section calles "How much does it cost?" It's the one with 4 columns in 4 different colors. I want to add a 5th column, next to the red colomn. But my Themler only add's a column above the plans, next to the header. Isn't it possible to add more than 4 columns? When I look at my website, after adding this section, it's already there, just like it's added. How can I edit the text? am I obliged to edit the text in the theme? or can it be done through my CMS? greetings Seppe
Support Team posted this 20 June 2016
Hello Seppe,
In fact, there are 5 columns - the first one is the top one. Would you like to add an extra column next to the last one (with "Plan 4")? An easy way to add it would be:
1. Select the right "Plan 4" column, right-click it and choose "Insert Column After".
2. The column will be added. Select Columns and adjust the width of all columns in Columns tab >> Width:
You may also copy and paste controls and containers into a new column or use the Copy Style and Paste Style option to make the new column similar to existing columns.
Hello Seppe, In fact, there are 5 columns - the first one is the top one. Would you like to add an extra column next to the last one (with "Plan 4")? An easy way to add it would be: 1. Select the right "Plan 4" column, right-click it and choose "Insert Column After". 2. The column will be added. Select Columns and adjust the width of all columns in Columns tab >> Width: !i334.png! You may also copy and paste controls and containers into a new column or use the Copy Style and Paste Style option to make the new column similar to existing columns. Sincerely, Nettie, BillionDigital Team
Seppe
Seppe posted this 21 June 2016
Good morning Nettie
Aha, that's how it's done.
Thank you very much
greetings
Seppe
Good morning Nettie Aha, that's how it's done. Thank you very much greetings Seppe
Seppe, you are welcome!
Seppe, you are welcome! Sincerely, Nettie, BillionDigital Team
