HI, I got this error when I tried to open the joomla editor for desktop.
Sorry, an error has occured. Please clear your browser cache.
I followed all the steps in the tutorial to fix it but I got as well the error.
Thank you for the help
C:\ProgramData\Themler
6. Download latest version of Themler for Windows from themler.com, install it and try to start with any CMS and create a theme.
Thank you. Just a question. Where can I find theme folders? And how can I restore them once I will install again the Themler fon Windows?
Thank you. Just a question. Where can I find theme folders? And how can I restore them once I will install again the Themler fon Windows?Hello,
If there are not too many themes, you may export them as zips one by one and then import them again as .zips in Themler.
If you would like to copy them alltogether, the themes are located at the path like this - at the bottom of the screen with CMS seelcted:
