BUG - Backward-Links?
Bayern
Bayern posted this 21 June 2016
New Version Themler v.310
The Backward Links could not be deleted
New Version Themler v.310 The Backward Links could not be deleted
9 Comments
This control can be hidden: Home tab >> Settings >> disable "Show Backlinks" option.
Hello, This control can be hidden: Home tab >> Settings >> disable "Show Backlinks" option. Sincerely, Nettie, BillionDigital Team
butterfly_webdesign
butterfly_webdesign posted this 24 August 2016
Is it possible to remove the backward links?
there's no need to remove the links. It's enough to disable them as described in the previous response and re-apply the theme to your CMS.
Hello, there's no need to remove the links. It's enough to disable them as described in the previous response and re-apply the theme to your CMS. regards, Aileen
LGWeb
LGWeb posted this 26 September 2016
I set mine to Display: None....
Every time I update Themler the backlinks displays again... I need this fixed please. Updates should not change my settings.
I set mine to Display: None.... Every time I update Themler the backlinks displays again... I need this fixed please. Updates should not change my settings.
LGWeb
Backlinks come back every single time no matter the setting if I update Themler.
Support Team posted this 28 September 2016
The backlinks back after updating theme to v349 because we reworked Backlinks control in this version. You need to update theme, disable backlinks and save changes. Next time when you update this theme to the next version, for example 352beta, the issue will not happen. I made a few tests with default Themler theme and everything is ok.
Hi, The backlinks back after updating theme to v349 because we reworked Backlinks control in this version. You need to update theme, disable backlinks and save changes. Next time when you update this theme to the next version, for example 352beta, the issue will not happen. I made a few tests with default Themler theme and everything is ok. Thank you, Olivia
kheidemann
kheidemann posted this 31 August 2017
My Backward Links are disabled in Settings but the Back Links Section will not disappear and there is no way to delete it. I have disabled this on other websites but it will not go away on this one. Any Suggestions?
kheidemann
Nevermind, It was still there even after restarting Themler, but when I went to change the Font, it suddenly disappeared after tinkering with the settings for about 30 minutes.
Support Team posted this 31 August 2017
Looks like some caching issue. Please let us know if our assistance is still needed.
Hello, Looks like some caching issue. Please let us know if our assistance is still needed. Sincerely, Nettie, BillionDigital Team
