Gap issue in template
galactic.adept.919
galactic.adept.919 posted this 22 June 2016
I am having an issue trying to get rid of a gap between the header area and the footer area. I have a photo with arrows pointing to the issue area. I cannot seem to get rid of that gap as you can see in the padding and margin area everything is set to zero. What can I do to get rid of that?
enter image description here
I am having an issue trying to get rid of a gap between the header area and the footer area. I have a photo with arrows pointing to the issue area. I cannot seem to get rid of that gap as you can see in the padding and margin area everything is set to zero. What can I do to get rid of that? ![enter image description here][1] [1]: https://s32.postimg.org/rp5gtkqc5/Themler_Question_3.jpg
Stagger Lee posted this 22 June 2016
Section from Clipart. Set image options differently. Keeping aspect ratio makes this. You have to sacrifice some part of image.
Support Team posted this 23 June 2016
If the issue is still actual please attach the theme so we could review the settings.
Hi, If the issue is still actual please attach the theme so we could review the settings. Sincerely, Hella
galactic.adept.919
galactic.adept.919 posted this 23 June 2016
That fix option must be for another scenario as even if I took the photo away as the background image of that column the gap issue was still there. I have attached the file into this post so it can be reviewed.
Support Team posted this 24 June 2016
Sorry, there is no file attached, please upload it once again.
Hi, Sorry, there is no file attached, please upload it once again. Sincerely, Hella
