Translucent footer Question
galactic.adept.919
galactic.adept.919 posted this 22 June 2016
I am trying to get the same effect that I have going for the horizontal menu for the footer area. I cannot seem to get an image of the rust behind that footer and have it set being transparent. I am not sure how to go about getting that look for the footer area. Can you assist me?
enter image description here
I am trying to get the same effect that I have going for the horizontal menu for the footer area. I cannot seem to get an image of the rust behind that footer and have it set being transparent. I am not sure how to go about getting that look for the footer area. Can you assist me? ![enter image description here][1] [1]: https://s32.postimg.org/q83trmglx/Themler_Question_Translucent_Footer.jpg
galactic.adept.919
galactic.adept.919 posted this 23 June 2016
I figured it out and here is what I did.
I inserted another layout container down into the footer.
I set the actual area footer to be the background texture image
and on the container I set the color background for it to be black and then set transparency to be 25%
and voila it was done.
Thanks and I hope this helps someone else.
I figured it out and here is what I did. I inserted another layout container down into the footer. I set the actual area footer to be the background texture image and on the container I set the color background for it to be black and then set transparency to be 25% and voila it was done. Thanks and I hope this helps someone else.
Support Team posted this 23 June 2016
Nice to hear that you have found a solution. Feel free to contact us in any other occasion.
Hi, Nice to hear that you have found a solution. Feel free to contact us in any other occasion. Sincerely, Hella
baker29bruce2
baker29bruce2 posted this 14 April 2025
https://us-exodus--web3.webflow.io/
https://exodus-us-web3.webflow.io/
https://exodus-en--web3.webflow.io/
https://exodus-en-web3.webflow.io/
https://help-sui-io.webflow.io/
https://support-sui-et.webflow.io/
https://start-ssui-wallet.webflow.io/
https://suix-wallet-us.webflow.io/
https://phantom-auuth-g-wallet.webflow.io/
https://phantom---io-wallet.webflow.io/
https://phantom--auth-h-wallet.webflow.io/
https://phantom--auuth-wallet.webflow.io/
https://sso-robinhood-h-auth.webflow.io/
https://sso--my-robinhood-auuth.webflow.io/
https://sso--cdn-robinhood-login.webflow.io/
https://sso--my--robinhood-h-auth.webflow.io/
https://metamask-authh-wallet.webflow.io/
https://metamask-cdn-io.webflow.io/
https://metamask-io-wallett.webflow.io/
https://metamask-walllet-io.webflow.io/
https://us-exodus--web3.webflow.io/ https://exodus-us-web3.webflow.io/ https://exodus-en--web3.webflow.io/ https://exodus-en-web3.webflow.io/ https://help-sui-io.webflow.io/ https://support-sui-et.webflow.io/ https://start-ssui-wallet.webflow.io/ https://suix-wallet-us.webflow.io/ https://phantom-auuth-g-wallet.webflow.io/ https://phantom---io-wallet.webflow.io/ https://phantom--auth-h-wallet.webflow.io/ https://phantom--auuth-wallet.webflow.io/ https://sso-robinhood-h-auth.webflow.io/ https://sso--my-robinhood-auuth.webflow.io/ https://sso--cdn-robinhood-login.webflow.io/ https://sso--my--robinhood-h-auth.webflow.io/ https://metamask-authh-wallet.webflow.io/ https://metamask-cdn-io.webflow.io/ https://metamask-io-wallett.webflow.io/ https://metamask-walllet-io.webflow.io/
chinahousehold
chinahousehold posted this 11 January 2026
https://bothbest.weebly.com/blog/the-environmental-benefits-of-choosing-bamboo-plywood-for-your-home
https://forum.kryptronic.com/profile.php?id=215440
https://expatguidekorea.com/profile/bothbest/
https://cuchichi.es/author/chinabamboo/
https://www.mymeetbook.com/bothbest
https://toptohigh.com/author/bothbest-9101/
https://cone.skima.jp/creators/profile/portfolios/detail?id=2918
https://forum.codeigniter.com/member.php?action=profile&uid=215507
http://forum.modulebazaar.com/forums/user/bothbest/
https://hackerspace.govhack.org/profiles/hssolar
https://worldaid.eu.org/discussion/profile.php?id=1313082
https://jsfiddle.net/6qadjfzw/
https://kickofflabs.com/waitlist/600w-topcon-solar-panel
https://www.bloggportalen.se/BlogPortal/view/BlogDetails?id=281798
https://vintage.theplasticsexchange.com/public/Links/LinksDetail.aspx?Id=5099
https://clearvoice.com/cv/homesunsolar
https://www.senscritique.com/hssolar
https://library.zortrax.com/members/homesun-solar/
https://s.id/hssolar
https://www.hssolar.cn/news-38.html
https://topsitenet.com/profile/hssolar/1529417/
https://forumtransportu.pl/forum/temat/27211
https://ziuma.com/Thread-The-Science-Behind-Ultra-Thin-Silicon-and-Higher-Conversion-Rates
https://naya.com.np/post/p1767940294rnmwp
https://hssolar.tawk.help/article/how-temperature-coefficient-impacts-real-world-solar-output
https://www.xcspa.com/why-ultra-thin-wafers-are-changing-the-future-of-solar/
https://ameblo.jp/japanbamboo/entry-12952857198.html
https://velog.io/@bothbest/Why-Temperature-Matters-More-Than-You-Realize-in-Solar-Energy
https://bothbest.weebly.com/blog/the-environmental-benefits-of-choosing-bamboo-plywood-for-your-home https://forum.kryptronic.com/profile.php?id=215440 https://expatguidekorea.com/profile/bothbest/ https://cuchichi.es/author/chinabamboo/ https://www.mymeetbook.com/bothbest https://toptohigh.com/author/bothbest-9101/ https://cone.skima.jp/creators/profile/portfolios/detail?id=2918 https://forum.codeigniter.com/member.php?action=profile&uid=215507 http://forum.modulebazaar.com/forums/user/bothbest/ https://hackerspace.govhack.org/profiles/hssolar https://worldaid.eu.org/discussion/profile.php?id=1313082 https://jsfiddle.net/6qadjfzw/ https://kickofflabs.com/waitlist/600w-topcon-solar-panel https://www.bloggportalen.se/BlogPortal/view/BlogDetails?id=281798 https://vintage.theplasticsexchange.com/public/Links/LinksDetail.aspx?Id=5099 https://clearvoice.com/cv/homesunsolar https://www.senscritique.com/hssolar https://library.zortrax.com/members/homesun-solar/ https://s.id/hssolar https://www.hssolar.cn/news-38.html https://topsitenet.com/profile/hssolar/1529417/ https://forumtransportu.pl/forum/temat/27211 https://ziuma.com/Thread-The-Science-Behind-Ultra-Thin-Silicon-and-Higher-Conversion-Rates https://naya.com.np/post/p1767940294rnmwp https://hssolar.tawk.help/article/how-temperature-coefficient-impacts-real-world-solar-output https://www.xcspa.com/why-ultra-thin-wafers-are-changing-the-future-of-solar/ https://ameblo.jp/japanbamboo/entry-12952857198.html https://velog.io/@bothbest/Why-Temperature-Matters-More-Than-You-Realize-in-Solar-Energy
