Change page content
jackymoore10
jackymoore10 posted this 23 June 2016
Hi, I am clicking on the menu item and pressing open link, but when I create a page it seems to affect all of the other menu items, why is it doing this? how do I fix this? built these pages several times now before I realised what was happening then just tried adding any content before proceeding. What am I doing wrong?
13 Comments
Support Team posted this 24 June 2016
Please check that you are adding the content inside the area marked with green, that should be post content. In other case the controls placed outside the content area will be the part of the template design and will appear on all the pages that do use that template.
Hi, Please check that you are adding the content inside the area marked with green, that should be post content. In other case the controls placed outside the content area will be the part of the template design and will appear on all the pages that do use that template. Sincerely, Hella
jackymoore10
jackymoore10 posted this 24 June 2016
Ok thanks, I don't have a green area page on my other pages, when I add an article the menu disappears. Sorry new here.
jackymoore10
Here in access to my site, jacky01/ benaaron01/ so you can have a look at what is going on. Already built some it once before accidentally deleting it so starting again.
Support Team posted this 25 June 2016
Sorry, could you please provide an URL to your site as well.
Also check that the CMS Content is enabled on those pages.
Hi, Sorry, could you please provide an URL to your site as well. Also check that the CMS Content is enabled on those pages. Sincerely, Hella
jackymoore10
jackymoore10 posted this 27 June 2016
www.redheadgraphicdesign.co.uk www.redheadgraphicdesign.co.uk/administrator
Support Team posted this 27 June 2016
Sorry, I failed to log in with those credentials, please could you type them once again.
Hi, Sorry, I failed to log in with those credentials, please could you type them once again. Sincerely, Hella
jackymoore10
http://www.redheadgraphicdesign.co.uk/administrator
Login jacky01/
password : benaaron01/
http://www.redheadgraphicdesign.co.uk/administrator Login jacky01/ password : benaaron01/
jackymoore10
jackymoore10 posted this 29 June 2016
did you manage to log in a find an answer?
Support Team posted this 29 June 2016
Your site looks a bit strange, not the same as on the screen shots you have provided. I see that the Content and Sidebars are not enabled in the Post template and that's why the site content is not showing in Themler. Try to enable it under the Insert >> Content and Sidebars and then the content should appear and you will be able to edit it (the one within the area marked with the green border).
Hi, Your site looks a bit strange, not the same as on the screen shots you have provided. I see that the Content and Sidebars are not enabled in the Post template and that's why the site content is not showing in Themler. Try to enable it under the Insert >> Content and Sidebars and then the content should appear and you will be able to edit it (the one within the area marked with the green border). Sincerely, Hella
jackymoore10
jackymoore10 posted this 30 June 2016
How do I get my logo to appear in the middle?
Support Team posted this 30 June 2016
In the middle of what? Header, menu?
In the middle of what? Header, menu? Sincerely, Hella
jackymoore10
of the sheet see attached.
Support Team posted this 01 July 2016
Hello Jacky,
to locate the Logo in center I'd recommend that you add Container control, set its Width to 100% and set Alignment to center.
Then move the Logo inside this Container
Hello Jacky, to locate the Logo in center I'd recommend that you add Container control, set its Width to 100% and set Alignment to center. Then move the Logo inside this Container regards, Aileen
