Custom.css
ruben20
ruben20 posted this 30 June 2016
I´m new using Themler and so far I love it, I have one question only...
Where is the custom.css??
If i want to add more css?? what do I do, where do I do it??
Gracias!!
Hello I´m new using Themler and so far I love it, I have one question only... Where is the custom.css?? If i want to add more css?? what do I do, where do I do it?? Gracias!!
Support Team posted this 01 July 2016
You can insert your CSS under the Home >> Settings >> Additional CSS. That code will be exported with the theme.
Hi, You can insert your CSS under the Home >> Settings >> Additional CSS. That code will be exported with the theme. Sincerely, Hella
webmetod
webmetod posted this 05 July 2016
Hi! A few days ago I finished design of the website, which I had to add (create and edit) 700+ lines of css-code. Built-in editor is inconvenient, no numeration of lines, not have search, after each change it is necessary to close and save the theme, then re-open and difficult search for the required line. My conclusion: a separate file with the styles, for editing in Notepad++ over FTP, would make my job much quicker!
Support Team posted this 05 July 2016
We'll consider your suggestion. For now you can edit the code in the Notepad and then copy and past into the application.
Hi, We'll consider your suggestion. For now you can edit the code in the Notepad and then copy and past into the application. Sincerely, Hella
webmetod
Thanks for the advice, but an external editor allow to quickly make changes, save, refresh the page in a browser, to evaluate the result, fix the code in Notepad and again to save (edit, ctrl+S, alt+tab, ctrl+R, alt+tab, edit and so on). In the built-in editor is not possible, it wasted a lot of time.
> Hi, > > We'll consider your suggestion. For now you can edit the code in the Notepad and then copy and past into the application. > > Sincerely, > Hella Thanks for the advice, but an external editor allow to quickly make changes, save, refresh the page in a browser, to evaluate the result, fix the code in Notepad and again to save (edit, ctrl+S, alt+tab, ctrl+R, alt+tab, edit and so on). In the built-in editor is not possible, it wasted a lot of time.
we appreciate all your comments. Please let us know do you need further help with this topic?
Hello, we appreciate all your comments. Please let us know do you need further help with this topic? regards, Aileen
