Css files deleted after saved a html theme
funmaking
funmaking posted this 01 July 2016
I need to link 2 css files in one of my html pages. I have put a "style" link in the additional html header. No problem.
I have created a new folder in the root of the html theme and I have put there the css files. When I save the theme, Themler delete the css files.
I have tried to put them in the assets/css folder with the same result. I don't want to put the css code in the "additional css" option of the properties of the page, because it's long and I want to link to one file.
Any hint to do this? The javasript files (.js) don't have this problem. I have a custom one in the /assets/js folder and it's working...
Hello I need to link 2 css files in one of my html pages. I have put a "style" link in the additional html header. No problem. I have created a new folder in the root of the html theme and I have put there the css files. When I save the theme, **Themler delete the css files**. I have tried to put them in the *assets/css* folder with the same result. I don't want to put the css code in the "additional css" option of the properties of the page, because it's long and I want to link to one file. Any hint to do this? The javasript files *(.js)* don't have this problem. I have a custom one in the */assets/js* folder and it's working... Thanks
6 Comments
Support Team posted this 04 July 2016
Hello Javier,
as workaround I'd recommend that you locate the .css file outside the ThemeName folder and will contact developer regarding how it is supposed to work.
Hello Javier, as workaround I'd recommend that you locate the .css file outside the ThemeName folder and will contact developer regarding how it is supposed to work. Regards, Aileen
funmaking
funmaking posted this 04 July 2016
Sorry but the theme will be in the root of the hosting, so it's not possible to put it in another location.
I will wait for a fix, thanks.
Sorry but the theme will be in the root of the hosting, so it's not possible to put it in another location. I will wait for a fix, thanks.
Support Team posted this 05 July 2016
Hello Javier,
just FYI: the suggestion about the selectable theme location is in our wish list but I cannot say when it'd be implemented.
Hello Javier, just FYI: the suggestion about the selectable theme location is in our wish list but I cannot say when it'd be implemented. Regards, Aileen
funmaking
funmaking posted this 06 July 2016
The problem is not the theme location, is the deletion of the css files. Please fix this. Thanks
Hello The problem is not the theme location, is the deletion of the css files. Please fix this. Thanks
Support Team posted this 06 July 2016
Hello Javier,
I see. Developers are working on it. We'll contact you when solution or workaround is available
Hello Javier, I see. Developers are working on it. We'll contact you when solution or workaround is available Regards, Aileen
funmaking
funmaking posted this 07 July 2016
Ok, thank you
Ok, thank you
