magento top menu
marco.marino1971
marco.marino1971 posted this 04 July 2016
I see in you documentation that to modify items inside magento topmenu, it is necessary to change the file "theme.xml"
Could you give us some more information?
Where is this file located?
Could you provide some example of how to modify one voice inside this menu?
Marco
I see in you documentation that to modify items inside magento topmenu, it is necessary to change the file "theme.xml" Could you give us some more information? Where is this file located? Could you provide some example of how to modify one voice inside this menu? Marco
Support Team posted this 05 July 2016
What exactly you want to change? The Themler Top menu uses Magento top links block. You can adjust the existing links in a usual way in Magento source files:
  • Login/Logout, My Account – customer.xml
  • My Cart and Checkout – checkout.xml
  • My Wishlist – wishlist.xml
in the \app\design\frontend\base\default\layout\ folder.
Hi, What exactly you want to change? The Themler Top menu uses Magento top links block. You can adjust the existing links in a usual way in Magento source files: - Login/Logout, My Account – customer.xml - My Cart and Checkout – checkout.xml - My Wishlist – wishlist.xml in the `\app\design\frontend\base\default\layout\` folder. Thank you, Olivia
