Is it possible to create video backgrounds for a page or header? Example: http://kre8ivu.wix.com/kre8ivu
- If so, how do I create this effect?
- If not, is this going to be an update in the future?
There is no such direct option for the background. But you can consider using the Video control with the absolute position and then set other controls on top of it so it will look like a background.
Eventhough there is no such standard functionality in themler, It is possible to create such a background. In fact it is very easy to realise. This is an example of my own site: www.cumaliaksu.nl
Just follow the next steps:
1) You first need to insert a slider section
(you need to clean te slider content by deleting all the containers and the image)
2) Now you have a blank slider you can add a video into the slider section.
(You need to delete also the Max width value and set the width and eight values of the video to 100vh and 100vw, select absolute positioning middle)
3) You can insert any functionality on the video by drag drop, but dont forget to put the value of the video layer into send to back, this is very important. Otherwhise all the insert will dissapear in the background.
Hope this will help!
Regards, Djumali
