Hi, I would like to have 2 columns next to eachother on a mobile divice instead of one.
Is there a way to do this?
You have a content in one column in the desktop mode and want it to go into two columns in the responsive mode? Please explain your question in more details.
Hi, no four columns in desktop and would like two columns in mobile
Hi, no four columns in desktop and would like two columns in mobileOpen the Columns control option and there will be a Columns drop down. There you can set the width for each column in each responsive view. It should be 25% for each column in the desktop, use 50% for each column in the phone view.
You are welcome. Let us know if you need our further assistance.
Hello. I have a real problem with the columns on mobile. I created 3 columns and I did as you said. I defined at the option Column 33%. The level in the mobile browser viewing is perfect; However, when I made an android application only link to the WebSite there is only one column that appears. What to do?
example : groupevelegda.com
download GroupeVelegda on playstore and test.
Hello. I have a real problem with the columns on mobile. I created 3 columns and I did as you said. I defined at the option Column 33%. The level in the mobile browser viewing is perfect; However, when I made an android application only link to the WebSite there is only one column that appears. What to do? example : groupevelegda.com download GroupeVelegda on playstore and test.Hi,
We do not support creating templates for the applications and I do not have possibility to test it on the Android phone.
