Support for Artisteer projects
RobR
RobR posted this 21 March 2015
So I read that there will be "Support for Artisteer projects"
So does that mean I will be able to design something in artisteer, export it, and then import it here & add these features to my existing artisteer themes?
That would be so awesome & if that is correct, is there an ETA as to when this feature maybe available?
So I read that there will be "Support for Artisteer projects" So does that mean I will be able to design something in artisteer, export it, and then import it here & add these features to my existing artisteer themes? That would be so awesome & if that is correct, is there an ETA as to when this feature maybe available? Thanks
9 Comments
Support Team posted this 21 March 2015
Rob,
Yes, we are working on importing ARTX projects.
Actually this is Themler export in Artisteer.
Oleg
Rob, Yes, we are working on importing ARTX projects. Actually this is Themler export in Artisteer. Thanks, Oleg
Dan Escoda
Dan Escoda posted this 17 April 2015
Rob,
Oleg
Dear Rob, Im paying Artisteer since few years ago and have lots of templates made to clientes that will need to import to Themler, for me this is the main point to stay with Themler, most of my clients need improvements and eventually modify/update old template so its necessary to be able to put the Artisteer template into Themler and continue working with it.
Will be great if you focus on this improvement as I thing its a key important.
Great app, best of the year for me!!
Danny
> Rob, > > Yes, we are working on importing ARTX projects. > Actually this is Themler export in Artisteer. > > Thanks, > Oleg Dear Rob, Im paying Artisteer since few years ago and have lots of templates made to clientes that will need to import to Themler, for me this is the main point to stay with Themler, most of my clients need improvements and eventually modify/update old template so its necessary to be able to put the Artisteer template into Themler and continue working with it. Will be great if you focus on this improvement as I thing its a key important. Great app, best of the year for me!! Thanks Danny
Support Team posted this 17 April 2015
Hi Danny,
This feature is in process.
It's quite complex. Therefore we need some time to implement it.
But we're working on it.
Hi Danny, This feature is in process. It's quite complex. Therefore we need some time to implement it. But we're working on it. Thank you, Olivia
ClaudiaK
ClaudiaK posted this 01 May 2015
Hi Olivia,
can you explain me, how can I export my themler theme into Artisteer?? Your wrote that it is possible...
thanks a lot
Hi Olivia, can you explain me, how can I export my themler theme into Artisteer?? Your wrote that it is possible... thanks a lot
Support Team posted this 03 May 2015
Claudia,
We're working on the feature that will allow to open Artisteer projects in Themler. But Themler theme can not be opened in Artisteer because these two application a quite different. They use different frameworks and themes has completely different structure.
Claudia, We're working on the feature that will allow to open Artisteer projects in Themler. But Themler theme can not be opened in Artisteer because these two application a quite different. They use different frameworks and themes has completely different structure. Thank you, Olivia
sonicthoughts
sonicthoughts posted this 28 May 2015
Fyi. Import of artx is critical. Artisteer abandoned us and now to make minor modification must upgrade to obsolete software. EVEN PARTIAL ARTX IMPORT WOULD BE OF HIGH VALUE! Please keep us posted as many are dubious of "coming soon". can support help manually import?
sonicthoughts
Fyi. I tried to vote and subscribe to this topic but the buttons don't work on my chrome mobile browser...
Support Team posted this 28 May 2015
Shawn,
The Artisteer projects support is a quite complex feature and we're still working on it.
Thank you for the reporting this issue with Chrome mobile. I've reported it to our developers.
Shawn, The Artisteer projects support is a quite complex feature and we're still working on it. > Fyi. I tried to vote and subscribe to this topic but the buttons don't work on my chrome mobile browser... Thank you for the reporting this issue with Chrome mobile. I've reported it to our developers. Thank you, Olivia
chinahousehold
chinahousehold posted this 08 March 2026
https://www.hssolar.cn
https://www.xcspa.com
https://www.bambooflooring.net
https://allmy.bio/bothbest
http://scenarch.com/scenarios/4107
https://codoc.jp/sites/bothbest/entries/TV91FQ7dtA
https://naya.com.np/post/p17727151530if6p
https://ameblo.jp/japanbamboo/entry-12958778757.html
https://www.expatriates.com/cls/62745422.html
https://forumtransportu.pl/forum/temat/36017
https://ticketme.io/account/bothbest
https://sngine.fr/blogs/34945/The-Most-Common-Mistakes-When-Buying-Bamboo-Plywood-Sheets
https://bothbest.firstory.io/posts/bamboo-panels-for-cabinets-pros-cons-and-design-ideas-v6rxmdjb488k
http://resurrection.bungie.org/forum/index.pl?profile=bothbest
https://bambooflooring.wowlaunch.com/
https://bambooflooring.wowlaunch.com/forums/viewtopic.php?t=12222880&gid=617589
https://bambooflooring.alboompro.com/post/how-bamboo-plywood-is-made-from-stalk-to-strong-structural-panel
https://arizonaadam.com/forum/topic/moisture-resistance-in-bamboo-plywood-how-it-really-performs/
https://mypaper.pchome.com.tw/bothbest/post/1383388958
https://kumu.io/bothbest/bamboo-beams-are-they-strong-enough-for-structural-projects
https://qrfonline.qrfmag.com/qrfswap/viewtopic.php?t=42846
https://www.hssolar.cn/news-49.html
https://docs.datananas.com/discuss/69aa7e25ba04f74bbc8b9531
https://roughstuffmedia.activeboard.com/t72588798/bamboo-lumber-vs-hardwood-which-performs-better/
https://bambooflooring.univer.se/how-to-maintain-and-finish-bamboo-panels-for-long-lasting-beauty
https://www.theconsumersfeedback.com/guestpost/bamboo-plywood-sheets-prices-in-2026-what-consumers-need-to-know
https://bamboo-flooring.jimdosite.com/news/
https://bamboo-flooring.jimdosite.com/news/how-to-maintain-and-finish-bamboo-panels-for-long-lasting-beauty/
https://www.thefreeadforum.com/postclassifieds/for-sale/home-furniture-garden/classifieds_for_free/bamboo-plywood-explained-types-grades-and-uses_i6322514/classifieds-for-free/los-angeles
https://www.efunda.com/members/people/show_people.cfm?Usr=bothbest
https://www.civocracy.org/user/48252
https://www.sooplive.co.kr/station/bothbest/post/188962791
https://bamboochopsticks.storeinfo.jp/posts/58613464
https://bamboodecking.themedia.jp/posts/58613470
https://bambooplywood.localinfo.jp/posts/58613468
https://chinabamboo.therestaurant.jp/posts/58613471
https://bambooflooring.shopinfo.jp/posts/58613473
https://bambooflooring.theblog.me/posts/58613478
https://japanbamboo.storeinfo.jp/posts/58613483
https://bothbest.amebaownd.com/posts/58613487
https://hackmd.io/@chinabamboo/B1lK4T-YFWg
https://md.sigma2.no/s/C-Mug7Yid
https://zumpadpro.zum.de/s/r1WD0-FF-x
https://md.coredump.ch/s/pHOdUSfOG
https://www.frenchwomenorg.com/read-blog/29992
https://www.glbrain.com/index.php?r=content/view&id=48731
https://ssn.so/forums/munpia-contest/topic/78773/
https://circle-book.com/circles/16446/blogs/108876
https://www.hssolar.cn https://www.xcspa.com https://www.bambooflooring.net https://allmy.bio/bothbest http://scenarch.com/scenarios/4107 https://codoc.jp/sites/bothbest/entries/TV91FQ7dtA https://naya.com.np/post/p17727151530if6p https://ameblo.jp/japanbamboo/entry-12958778757.html https://www.expatriates.com/cls/62745422.html https://forumtransportu.pl/forum/temat/36017 https://ticketme.io/account/bothbest https://sngine.fr/blogs/34945/The-Most-Common-Mistakes-When-Buying-Bamboo-Plywood-Sheets https://bothbest.firstory.io/posts/bamboo-panels-for-cabinets-pros-cons-and-design-ideas-v6rxmdjb488k http://resurrection.bungie.org/forum/index.pl?profile=bothbest https://bambooflooring.wowlaunch.com/ https://bambooflooring.wowlaunch.com/forums/viewtopic.php?t=12222880&gid=617589 https://bambooflooring.alboompro.com/post/how-bamboo-plywood-is-made-from-stalk-to-strong-structural-panel https://arizonaadam.com/forum/topic/moisture-resistance-in-bamboo-plywood-how-it-really-performs/ https://mypaper.pchome.com.tw/bothbest/post/1383388958 https://kumu.io/bothbest/bamboo-beams-are-they-strong-enough-for-structural-projects https://qrfonline.qrfmag.com/qrfswap/viewtopic.php?t=42846 https://www.hssolar.cn/news-49.html https://docs.datananas.com/discuss/69aa7e25ba04f74bbc8b9531 https://roughstuffmedia.activeboard.com/t72588798/bamboo-lumber-vs-hardwood-which-performs-better/ https://bambooflooring.univer.se/how-to-maintain-and-finish-bamboo-panels-for-long-lasting-beauty https://www.theconsumersfeedback.com/guestpost/bamboo-plywood-sheets-prices-in-2026-what-consumers-need-to-know https://bamboo-flooring.jimdosite.com/news/ https://bamboo-flooring.jimdosite.com/news/how-to-maintain-and-finish-bamboo-panels-for-long-lasting-beauty/ https://www.thefreeadforum.com/postclassifieds/for-sale/home-furniture-garden/classifieds_for_free/bamboo-plywood-explained-types-grades-and-uses_i6322514/classifieds-for-free/los-angeles https://www.efunda.com/members/people/show_people.cfm?Usr=bothbest https://www.civocracy.org/user/48252 https://www.sooplive.co.kr/station/bothbest/post/188962791 https://bamboochopsticks.storeinfo.jp/posts/58613464 https://bamboodecking.themedia.jp/posts/58613470 https://bambooplywood.localinfo.jp/posts/58613468 https://chinabamboo.therestaurant.jp/posts/58613471 https://bambooflooring.shopinfo.jp/posts/58613473 https://bambooflooring.theblog.me/posts/58613478 https://japanbamboo.storeinfo.jp/posts/58613483 https://bothbest.amebaownd.com/posts/58613487 https://hackmd.io/@chinabamboo/B1lK4T-YFWg https://md.sigma2.no/s/C-Mug7Yid https://zumpadpro.zum.de/s/r1WD0-FF-x https://md.coredump.ch/s/pHOdUSfOG https://www.frenchwomenorg.com/read-blog/29992 https://www.glbrain.com/index.php?r=content/view&id=48731 https://ssn.so/forums/munpia-contest/topic/78773/ https://circle-book.com/circles/16446/blogs/108876
